Old 02-08-2010, 11:45 AM   #1 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
Flat panels inside wheels?
Hi,
I saw this vision of flat panels inside wheels. Panels would fill the underside of the wheel so there still would be little ventilation to brakes from the upper half of the hole...
Rear wheels should be easy job, just welded steel plate to proper place.
Front gets little trickier, because of the turning wheels, but could be done.
What do you think?
This should not hurt much about brakes ventilation?
If you already have flat hubcabs and underside you would get the most benefit of this mod?
Old 02-08-2010, 12:06 PM   #2 (permalink)
Eco Dreamer
Versa - '08 Versa SL Hatchback
That is basically a dust shield. A more aero-friendly DIY version of this should be real simple. You are talking about covering the brakes, these go between the brakes and the wheel, other than that, I think this is the same thing.
Kleen Wheels are dust shields which protect your wheels from brake dust
Old 02-08-2010, 12:33 PM   #3 (permalink)
Vekke's Avatar
Diesel
Yes basically a flat dust shield in a aero friendly place and shape.
My vision was that those panels would not rotate, because still panels are better for aero?. Those would come just as close you can safely put those to wheel arches...
Old 02-08-2010, 01:25 PM   #4 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I'd suggest looking back there. On most of my stuff the brakes pretty much fill up the whole backside of the wheels anyway.
Old 05-20-2010, 01:43 PM   #5 (permalink)
Vekke's Avatar
Diesel
Now I have done this mod to rear tires and here is the picture:
IMG_7507.JPG - Windows Live
I think those help at least little. Still brakes get cold air from the upper side of the inside rim... And you dont need so much cooling if you drive economically...
Old 05-21-2010, 12:38 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Mine too. And they already have dust shields that fill up most of the area that isn't filled by calipers and rotors.
Winter daily driver, parked most days right now
Summer daily driver
Alloy wheels + Metallic Tape = Aero Racing Disk cfg83 Aerodynamics 20 06-09-2010 03:23 AM
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 06:37 PM
THE Best Coroplast For Flat Underbody Panels! Blue Bomber Aerodynamics 17 04-16-2009 04:53 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
The finest Chinese cr*p that money can buy. (wheels & tires) lyd EcoModding Central 13 09-30-2008 05:41 PM
