Old 12-10-2013, 07:02 PM   #1 (permalink)
Flow Illustrator shows that Inchul Kim/Metacomp spoiler works nicely!
This custom designed spoiler has been discussed before
Novel Spoiler Design Reduces Fuel Consumption for Minivans, SUVs
Green Car Congress: Novel Spoiler Design Reduces Fuel Consumption for Minivans, SUVs
So far I don't know how to "copy" videos generated by Flow Illustrator (please show me how) so I posted the bitmap images it requires
Its bitmap image
Rotated as Flow Illustrator flows from the left side
A teadrop Kamm without spoiler
And with the spoiler
A top-down convertible car with the spoiler on the windshield header
A follow up from An inverse windshield top spoiler for convertibles when top down? post
http://ecomodder.com/forum/showthrea...own-27155.html
I believe the spoiler can also help reattach underbody flow.
The same car without such spoilers
The bare spoiler
By the way How can you overlap a car and this spoiler image without having Photoshop to trim the borders?
Is there any nice, free and easy to use software to trim the spoiler image edges paste it over a car image?
Old 12-10-2013, 07:14 PM   #2 (permalink)
So far I've only used Power Point to overlap images but I got something like this
So I need an imaging software
Old 12-10-2013, 07:23 PM   #3 (permalink)
I truly believe this spoiler has the potential to help reattach and redirect flow as to reduce its wake cross sectional area.
This may be used in the backlight header, backlight sides, under the rear bumper and in trunk rear outer edges integrated in the bodywork.
Old 12-11-2013, 09:00 AM   #4 (permalink)
According to the article:
aerodynamic drag and lift on a mini-van moving at 108 kph (67 mph)...............bluff-backed vehicles.............
I think that outside of the applications listed above you are in a very gray area.
For instance most of the locations you show would do little to help and may even harm the aerodynamics.
The top of the windshield location has been discussed in a another thread. I am doubtful to it's usefulness here.
The patent drawing looks to be a similar profile to a teadrop Kamm, but I suspect that was a precaution to insure it worked at all prior to testing.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
