Old 05-30-2011, 04:59 PM   #1 (permalink)
Thumbs up Fluidviz for flow examinasion
There is another way to show flow then tuft testing or windtunnel smoke testing, its nicknamed Fluidviz =fluid visualisation.
They use a parafine based oil, with flourecent pouder in it.
After you did your run you can examen the flow quite good.
The use this in F1 in real training, becouse this gives real world results even though they use the windtunnel 24-7.
At the University TU Delft they also use it.
some examples
Mclaren Mercedes MP4-25 - Forum - F1technical.net
Red Bull RB7 – getting green at Jerez (February test) « Formula 1 tech and art's Blog
Tu delft bobsleigh
http://www.tudelft.nl/live/binaries/.../2006_1_15.pdf
Oil flow visualization
To visualize the surface flow an oil flow visualization technique has been applied. First
petroleum was applied to create a smooth surface. The mixture for the visualization consists
of the following components:
Shell Ondina 68 Paraffin; viscosity thick.
• A680 fluorescent oil additive.
After the oil is applied the model is illuminated with ultraviolet light. The oil flow
measurements were done at approximately 60 m/s. For an example see figure 3.13.
Figure 3.13: Example of oil flow visualization
Old 05-31-2011, 04:51 PM   #2 (permalink)
Are there people here that tried it already?
Old 05-31-2011, 11:11 PM   #3 (permalink)
Instead of parrafin, use thick liquid car wash and add food coloring, if needed. Easy wash off.
German sailplane guys use oil and add lamp black. Same idea.
Old 06-01-2011, 12:13 AM   #4 (permalink)
XJguy's Avatar
Engine oil will do the trick as well. I was planning on doing this once I have my complete aero package finalized.
Old 06-01-2011, 12:39 AM   #5 (permalink)
Lead-footed Econewbie
Ceffy - '97 Cefiro 25 excimo
90 day: 23.27 mpg (US)
Used engine oil on paint would not be such a good idea. Not even so sure about the fresh stuff with it's additives these days. I used some brightly colored wash 'n' wax for flow "examinasion" worked a treat. No chance of it interfering with my metallic paint. UV rays down here are ruining the last of my clearcoat without extra help.
