Welcome to ecomodder.
Originally Posted by MPGranger
I want to see if I can double the factory fuel economy.
Starting with 22 city/27 highway MPG, it ain't going to be easy.
You won't get there by buying stuff to put in the tank.
It's going to be hard work.
To give you an idea,
cleampg.com put some of the best hypermilers in an F150 Ecoboost and let them have a go with it.
They didn't double the factory fuel economy numbers - 17 city/23 highway MPG - though they did get 32.3 despite 2000 lbs of load (gear + pax).
It's possible though.
DieselDave did double the numbers for his Ram 2500.
My first 1,000+ mile tank!
Have a look at his posts to see how he's doing it.
Right now all I have done to the truck is a drop-in K&N air filter and a magnaflow muffler.
They're unlikely to help much though.
My drive to work is 10 miles of 65mph highway and 6 miles of construction hell.
If you do short trips, you could get an oil more tailored to that sort of use.
Get off the highway.
DieselDave :
most of the time I'm at 45 mph or lower.
I am going to have the oil changed soon and I plan to put in the lightest weight synthetic oil.
That works, especially for cold starts.
Get a "fuel efficiency" oil that meets the required specs for the Ranger.
Lighter transmission oil also helps a bit.
Big question, does anybody suggest using fuel additives to increase MPG? Do they actually clean your engine as they suggest? Are they cost effective?
Good fuel is good as-is.
You can try the premium fuels and see if they work for your vehicle - but they're just going to push you a few % further (at a cost).
See the hypermiling tips and start practicing as many as possible :
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
A couple eco-mods wouldn't go amiss either:
65+ Vehicle modifications for better fuel economy - EcoModder.com
Increased tyre pressure; an aero bed cover ; grille-block; air dam; belly pan seem like a good start.
I don't want to discourage you, but 50mpg already takes a bit of work on a passenger car ...
