Hi All
as a follow up from my previous thread
Mpgunino calibration help
I have found that filling just below the filler neck provides repeatable results so I have managed to calibrate.
And after following the calibration instructions I now have the following numbers:
new vss pulses = 127708
new microsec =1493884771
My injector delay is still set to 500.
Odd thing is, after calibrating the vss pulses, the mileage still doesnt match my dashboard (which is what I used to provide the odo readings. Not by much though, out by maybe 1.5miles per 100 miles). The very odd thing is the maths on my
mpguino doesnt make sense, as per following pic:
I dont see how my tank is currently 23.06 mpg when I have used 1.31 gallons and have done 107.61 miles? Surley thats 82.1mpg
I will get there in the end!
