Old 01-27-2010, 07:13 AM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Ford claims new 6spd increases FE up to 9%
Apparently they are using a 6 speed manual and a 6 speed automatic. The article only claims that the auto gets the 9% though. From the rest of the article though, the new Focus is shaping up to be a nice car.
The updated 2.0L engine will be mated to either a 6-speed manual or a new 6-speed dual-clutch automatic transmission. Dubbed “PowerShift,” the new line of small-car automatic transmissions can reduce fuel consumption up to 9%, the company says.
New Ford Focus Outclasses Current U.S. Model
The Following User Says Thank You to Daox For This Useful Post:
aerohead (02-27-2010)
Old 01-27-2010, 08:01 AM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Now, if they give both the manual and the auto nice, tall gearing, and only off cruise (throttle?) control on the automatic!
Old 01-27-2010, 08:31 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
The auto probably has an ECO setting in its software to change gears at lower rpm. If a normal auto had similar (many do), then that would give 2%-5% savings over "normal" mode.
Piwoslaw's Peugeot 307sw modding thread
Old 01-27-2010, 08:31 AM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...or, conversely, how about having the ECU provide driver-switchable "ECO" and "PWR" control settings over the transmission?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 01-27-2010, 12:56 PM   #5 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
The "Automatic" is a computer shifted manual, thus the 9% savings and the term "power shift" being used to describe it. I've seen it and lust after it. It is also tiny and very light compated to any manual or automatic I've seen. I believe this was developed with a German company, I think Getrag?
Old 01-27-2010, 01:34 PM   #6 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Not surprising, Ford seems to be pointing their FE attempts toward their auto transmissions, especially in the Focii.. in fact, some auto Focii already get better FE than the manual versions on the highway. (EPA)
Old 01-27-2010, 01:36 PM   #7 (permalink)
Steve - '92 Festiva
Gas Mileage of 2002 Ford Focus
The Wagon models reflect it in City mileage at the bottom of that chart.
Old 01-27-2010, 06:08 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Tygen1 -
Yup (from URL posted by Daox) :
Gone is the aging 140-hp 2.0L Duratec DOHC inline 4-cyl. that powers the current Focus. In its place will be a new 2.0L direct-injected I-4 with twin independent variable camshaft timing that is expected to generate at least 155 hp while also providing improved fuel economy.
Ford says a version of its turbocharged EcoBoost D1engine eventually will be offered on the Focus.
Ford’s PowerShift transmissions, developed with German supplier Getrag GmbH & Cie KG, essentially consists of two manual transmissions working in parallel, each with an independent clutch unit.
In comparison, the current North American Focus is available with either a 5-speed manual or 4-speed automatic transmission. Ford says advanced 6-speed transmissions such as PowerShift will be offered on nearly its entire vehicle lineup by 2013.
CarloSW2
American Solar Energy Society
Old 01-27-2010, 07:48 PM   #9 (permalink)
Driving the TurboWeasel
Any of us with a manual could still slay the automatic's FE around town. Steady-state highway cruising is where it may have an advantage. You can't beat the FE of engine-off, though!
2012 Chevrolet Cruze Eco 6MT
Old 01-27-2010, 07:58 PM   #10 (permalink)
Team ZX2
Additionally it has a coast down feature that disengages the clutch to allow you to coast further with just a tap of the break, so theoretically you could put in a kill switch that kills the injectors and signals the computer that the brakes have been activated. EOC in an ATX !
Shell claims new "FuelSave" gasoline formulation increases fuel economy MetroMPG General Efficiency Discussion 32 11-07-2010 06:12 AM
Skeptical of "blade" exaust tip FE / emissions claims Cd EcoModding Central 42 01-14-2010 10:44 PM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 06:45 PM
Opposed-piston opposed-cylinder engine claims 50% FE increase Piwoslaw General Efficiency Discussion 6 10-24-2009 09:02 PM
Ford, making money? It must be a mistake... SVOboy General Efficiency Discussion 3 04-28-2008 09:28 PM
