Originally Posted by Big Dave
One can again get a PHILL home gas compressor for about $4,700.
No CNG stations anywhere near you ?
$ 4700 would buy a lot of gas.
I drive a good deal more than the average Joe - about 30,000 miles a year.
That's what makes it viable.
I can get the LS engine converted to CNG for about $9,000 installed.
That's steep.
A 4 in line conversion will run about 3000 - 3500 EUR locally.
(USD and EUR are worth about as much )
More cylinders means more injectors though, and you'll also need bigger tanks, but still ...
CNG is much cleaner burning so maintenance is greatly reduced.
Power is often down by about 10% as well, unless it's restored by tuning the mixture, and power delivery is more gradual - hence CNG vehicles will feel more
sluggish - so the tranny might cope better with the lower power
Less power means you're further up the load curve, which should be OK for MPG with steady driving - but not in the conditions where you need lots of power.
At this stage I'm thinking a bi-fuel conversion. If CNG gets more commonly available (for trips) I'll go fully CNG.
The normal practice with conversions is that the regular fuel tank stays in place, so you always have an expensive back-up.
OEM car conversions usually sacrifice most of the regular fuel tank to mount the tanks - which also changes their official status to CNG car in the EU
- on a light truck you'll probably have plenty of space to put the tanks.
