Free: Broken Scangauge II.
5 Attachment(s)
Buyer pays whatever actual expenses (paypal/shipping). Includes the unit/cable/original box/instructions/unused velcro strips.
I bought it in February of 2008 and used it until 2015 or so. At that point I'd just use it to check and clear codes. The good? I think someone can fiddle with it and have something that works. The cable appears to be fine all the way up until the last inch, so if that's an issue it can be cut and crimped giving you an extra cable. But there is a lot of bad. The top part on the front of the case is cracked in the middle. The legs of that top part you screw the bottom section into are basically broken off and gone. It sort of still stays together. I remember a few dead/stuck pixels in the display, you could still tell what you were monitoring. The socket on the side stopped working, so I switch to the rear. That gave me issues later so I used a rubber band. This caused the socket to delaminate from the board. As far as the cable goes, I could only find continuity between 5 of the 8-9 wires. Free pickup near SE Charlotte. I'll leave this up for a month but after that onto the landfill it goes. I have perfect selling feedback on ebay and neons.org if that's any concern. |
I'm sure someone here will pick it up. Nice of you to offer it.
But don't throw it out if nobody claims it! If it comes to that, I'd personally look at fixing it, and then giving it away. |
Does it still read the gauges?
Currently it's really hard to get it to connect/have power because of the socket/cable. It would only read connecting and then without pushing a button it would say codes cleared and stat that way until it lost power.
