Old 04-06-2011, 09:04 AM   #21 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
If it was me, I'd be looking to swap that engine from the Tempo into a newer escort wagon shell.
Old 04-06-2011, 09:41 AM   #22 (permalink)
Steve - '92 Festiva
Correction - if you don't need the cargo/family space, an mx3 chassis would be perfect. Lighten it up, of course, but it comes with an oem kamm shape, and a pinched nose that could translate into excellent aero with a few little tweaks here and there.
Old 04-06-2011, 02:31 PM   #23 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
If the Tempo doesn't have fatal structural rust, I'd just run it.
Old 04-07-2011, 02:08 AM   #24 (permalink)
vacationtime247's Avatar
The S cart - '91 Ford Escort Wagon LX
90 day: 33.66 mpg (US)
Pint-oh! - '78 Ford Pinto Pony
Black Beauty - '89 F-350 Dually Diesel Lariat XLT Crew Cab
90 day: 17.67 mpg (US)
The Toylet - '87 Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 51.12 mpg (US)
Family Truckster - '92 1992 Diesel Caprice Station Wagon project
Ass Tick - '01 Pontiac Aztek GT 5 Door
DoGo#2 - '99 Durango Dodge Durango SLT
Working on getting it at least up and running. The starter motor is froze up. Can't get it to turn over. Engine isn't locked up! That's good. Spins over freely with a socket and ratchet on the alternator bolt. Spent a few hours cleaning the mouse poop, squirrel nests and 12 years of garbage out today. Need to get the electric pressure washer out then blast away the leaves and gunk.
First thing is to just get it running. Once the starter issue is fixed, should be easy.
Does diesel fuel ever go bad over time like gas?
VT247
Old 04-07-2011, 02:17 AM   #25 (permalink)
Underside doesn't look bad. But the bottom of all the doors have holes and rust. The exhaust looks like it's going to need fixed. The back drivers side brake was locked. It broke loose, but can tell it's going to drag, will need fixed. The brake fluid reservoir is dry. It's farm fresh and has sat for around 12 years. Will see where I stand when it's at least drivable. Will try and upload a video tomorrow on where I'm at with it.
VT247
Old 04-07-2011, 02:29 AM   #26 (permalink)
That would be sweet! Hadn't considered one of those but I'd want it to be factory 5 speed. Whatever I drop it into should be a simple bolt in. Mazda designed these engines with the same basic deminsions as an FE motor. Same basic size and bell housing. Not sure about the mounts yet. From what I've gathered so far the 1:1 axle ratio is 3.73 Think I could go lower with a gas engine 5 speed. Need to find an interchangability list for the FWD Ford / Mazda engines & manual trans such as the years and models etc.
VT247
Old 04-07-2011, 06:28 AM   #27 (permalink)
Steve - '92 Festiva
As far as interchange, anything that mounts on the same side, and was masted to a1.6, 1.9, 2.0, 2.3, or 2.8, possibly. The 4 cylinders I'm sure about, though.
Diesel doesn't go bad, perse, but its always best to start with some clean fuel, so it's not suspect. Having sat for so long, I'd get some purge from the VW Parts place, or someplace similar, and run it onthat, or st least run ATF through it.. ATF will start it good and lube it up. Prime the pump with a hand siphon, prime each injector by cranking with the fuel feed for the injector loose, use a hot airgun on the intake while cranking when you finally intends to start it. If you, can, best to manually operate the oil pump with fresh oil, to prevent falling on e what will amount to dry bearings.
Old 04-07-2011, 07:03 AM   #28 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
VT247
You'll probably find that the only place to get a starter is Ford?...they will burn out if you try to start with a low battery.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Old 04-07-2011, 07:09 AM   #29 (permalink)
Steve - '92 Festiva
Talk to your local core rebuilder about either obtaining a rebuilt starter, or having yours rebuilt.
It's possible that you can fit a much larger starter (length, for more torque), by changing the front casio on the new starter to the one on your current starter. Often, with oddball parts like that, especially ones with an identified weakness, its best to see what else fits. Also check with 1.9/2.3 starters.
Old 04-08-2011, 01:36 AM   #30 (permalink)
Here is a video of both the vehicles.
VT247
