Old 08-20-2010, 07:57 PM   #11 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
Tollo - Many vehicles use temperature compensated charging to avoid that problem. My Jeep has a temp sensor in the battery tray to monitor battery temp. In hot summer weather, the voltmeter sits around 13.8 or so normally, a little less if the engine bay is really heat-soaked. In cold winter weather, it's around 14 - 14.1 due to the colder battery.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 08-22-2010, 12:20 PM   #12 (permalink)
I think some vehicles use temperature compensated charging and many does not. ... (I might be also wrong) How common is it ?
High temperature damage battery even when temperature compensated charging is used. (cool or "room temperature" is better)
euromodder - Cold temperature lowers the capacity of the battery. You won't probably not see any difference in battery voltage if you don't have temperature compensated charger.
Cold battery has less energy loss. That is the reason for better total FE.
Old 08-22-2010, 01:40 PM   #13 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
I've left a gap in my grill block, right where the intake to the battery is located.
Lifetime fuel consumption :
Old 08-23-2010, 12:41 AM   #14 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
It's so common I've never heard/read/seen it before
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 90 04-01-2012 06:11 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 5 10-09-2009 11:09 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
