Old 06-13-2013, 02:43 PM   #1 (permalink)
New to the Ecomodder world
Hello everyone. I have a 2000 Hyundai Elantra that i have owned for several years. I have tried a couple different mods over the years to play with fuel economy. I built a grill block from plexi glass but my car could not maintain a low enough engine temp so i had to remove it (no notable fuel savings while it was installed). I have tried warm air intake and cold ram air intake (noticeable power changes but no fuel econ change). I bought a Scan Guage but found that my normal driving style was already about as fuel efficient as it could be. I have toyed with the idea of deactivating two cylinders but in previous attempts on an older Hyundai fuel econ stayed about the same. (all I did was run a switch to two fuel injectors and turned em off while cruising at highway speeds). I have just installed a "restricter plate" just before the throttle plate with the theory that it will force my throttle plate to be open just a little more at hwy speeds reducing the sucking force on the engine, I have no faith in this working but I will have real numbers soon. My car right now fully stock *(before the plate) gets between 35-38 highway (it is only rated to 30 epa). I want to see 40 but can never quite get there. Any ideas?
Old 06-13-2013, 02:51 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
welcome!
1. pump up tires to 40+ psi
2. when buying new tires, upsize! THis will lower the final rear ratio. several good threads on this topic.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-13-2013, 06:51 PM   #3 (permalink)
Welcome to EM! The thing about aero mods is that you have to learn how to take advantage of them - by coasting more often and farther and in places that you could not coast without the mod. You have to learn to lift your right foot sooner and if you have a ScanGauge or an UltraGauge, you need to use it for a while to learn to take advantage of the aero mod.
