Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 03-17-2008, 10:26 PM   #11 (permalink)
JadeAccent - '01 Accent GL
90 day: 35.06 mpg (US)
Sonata - '011 Sonata Hybrid base
90 day: 35.48 mpg (US)
Is there any special trick to getting the mended link to not be too tight after closing the chain with the chain rivet tool? I've tried to get the rivet back in just right, but no amount of adjustment seems to get that link as smooth as the others.
Old 03-18-2008, 01:24 PM   #12 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 metro 4 dr HB
90 day: 66.44 mpg (US)
I usually flex the chain back and forth in the sideways direction (the way it isn't meant to bend)to loosen the newly pinned joint up.
Hope that helps
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 03-18-2008, 03:55 PM   #13 (permalink)
Thanks for the suggestion for the chain. I'll try it.
As far as the wiring, I found a DPDT switch with a center off position at Radio Shack today and am wondering if I could simplify the schematic like this (not sure if that's the correct way to depict the switch, but it should be logical at least):
Any ideas?
Old 03-18-2008, 04:05 PM   #14 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I don't see why that new switch config won't work.
What's the switch rated for? Without a controller to limit current, a switched setup can potentially draw quite a bit of current under stall/high load conditions. Not sure what's typically seen on a 24v e-bike though.
Old 03-18-2008, 04:40 PM   #15 (permalink)
The switch is rated for 20A at 12V.
Old 03-18-2008, 05:59 PM   #16 (permalink)
H4MM3R's Avatar
350W/24V=15A.
20A*12V=240W
Not sure what your trying to do here. Are you working with 12V or 24V system?
Old 03-18-2008, 06:35 PM   #17 (permalink)
I believe its set up so that the 24v gives you the acceleration/cruising, while the 12v is switched on for regen when going down hills.
Correct me if im wrong
S.
Old 03-18-2008, 10:47 PM   #18 (permalink)
S.
That's basically it. The only thing I'd add is a 12V step in acceleration from a pedal start, assuming it has anything to add running at 12V.
Hammer, my point about the switch rating is that I'll be a little under the current rating and twice the voltage rating. I'll test it thoroughly first.
Also, I thought of a problem with using the center off DPDT switch configured like the schematic above: The charging socket won't work - it'll just spin the motor. There has to be a switch to take the motor out of the circuit. Back to two switches.
Old 03-18-2008, 10:51 PM   #19 (permalink)
H4MM3R's Avatar
Thanks for helping me understand.
Old 03-19-2008, 02:48 AM   #20 (permalink)
Here is a pretty sweet homebuild:
http://www.peltzer.net/ebike/
Its got a huge motor & sweet belt drive!
S.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1484 01-08-2012 11:12 PM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 09:44 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 05:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 02:23 PM
