Old 07-03-2008, 09:28 AM   #21 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Yeah, Gurney invented the flap on the trailing edge of a wing. However, the effect holds wherever you put a 90* half inch flap. I think racers in general refer to those flaps as Gurney flaps. If you put on on the front half of the wheel arch, you will generate a slight vaccuum behind it, pulling air out of the wheel wells.
Old 07-03-2008, 10:09 AM   #22 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
i thought they where more to prevent air from being sucked in the wheelwell, as there's a lower pressure on the inside of the wheelwell.
also i've seen versions of these dams up close on certain new VW's like the pasat, that had an opening above them with a naca intake like duct in front of them, wich would lead air above them dams into the wheelwell. i assume this is for break cooling. but this would in my view, limit the effect of the low pressure area behind the dam (as well as prevent high pressure from form in in front of it)
i wish there was some good information available on how these dams actually work... i'm going to install them on my car, but it's hard to make something that works when you don't understand what it should do, and how it does that!
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 07-14-2008, 04:52 PM   #23 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ranchero GT
Spaz - '83 S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
In the Formula 1 circuit I have heard the strip at the trailing edge of the wing called wickerbills. They are interchangeable for different aero effects. I have heard it on a couple of different occasions by different announcers. The most notable, Jackie Stewart.
Honda...the economical, renewable resource.
Old 05-17-2011, 02:44 PM   #24 (permalink)
I've Been AeroHauled
Clever. So who's building it? I need to follow this one.
aerodynamics, fender skirts, wheel skirts
2007 Focus Front Air Dam garys_1k Aerodynamics 23 12-28-2011 03:22 PM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 04:09 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 08:45 AM
Yet Another Pickup Bed Cover Idea Big Dave Aerodynamics 4 05-17-2011 02:47 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 04:10 PM
