FS: 01 Insight 5 speed engine/trans and ecu
168k miles. 20k on clutch.
I pulled it out for a k series swap. that I had laying around for a civic The Bad: Needs trans input shaft bearing and synchronizer for 2nd (only ever ground when downshifting) Needs new 02 sensor. The Good ZERO oil leaks, recent valve adjustment and egr cleaning, and its from THE O.G. eco car. Make me an offer, I have no use for it. :thumbup: For the right price I can deliver. |
BUMP! will even take $100 includes ecu
I'd love to have an extra engine and transmission laying around, but Lubbock is pretty far.
It's only 2000 miles
Are you getting rid of the main harness from the rear battery box to the front ima?
I have not pulled the ima harness, but I will at some point.
I am reusing the hybrid power cables for the rear mounted battery |
Interested.
I have until the 18th of May to get rid of it, otherwise it's going to the scrap yard
