vxhatch |
03-14-2017 12:08 PM |
Fs: 1992 vx
I've decided to sell my beloved 1992 VX, which has been my reliable and thrifty gas saver. It's Tahitian Blue Pearl (aka Teal) Federal model with AC. Meticulously maintained with only synthetic lubes. Everything works. Pictures to follow when I am able to give it a good cleaning. Car is completely stock and could be sold with either 14" HX or the original 13" VX wheels.
Car is not perfect, but it presents well and the paint is in great shape for its age. Look closely and you'll notice typical civic rear wheel arch rust is just starting to appear, and car will need rear control arm bushings replaced to pass MD inspection. 212k, runs perfect and it's and totally reliable; turn the key and drive anywhere. Car is in Annapolis, MD; $2,500/firm, as is. Doug
water pump / timing belt done at 130k, new clutch and trans overhaul at 200k, (noisy input shaft bearing). It's been the most reliable car I've owned, ever...
