Old 11-03-2010, 09:37 PM   #11 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
What detonation? The fuel is injected in stages in multiple injections per combustion event.
Detonation occurs before TDC, while this injection sequence creates peak pressures by initiating combustion after TDC, then adding more fuel in sequential injections to control the pressure wave.
Did you read the information?
The goal is HCCI which virtually eliminates any post combustion exhaust treatment by creating a homogenous mixture that all ignites simulatneously, instead of detonation where there is a pressure wave initiated before TDC.
It could care less about octane rating.
regards
Mech
Old 11-04-2010, 03:22 AM   #12 (permalink)
you are getting into semantics. You know what he meant, as we all did. Because you offer more detail doesn't make him wrong because he generalized. Everyone knows the limits of generalizations. Did you expect him to write a scientific dissertation? Your argument could be taken apart just as easily. For example, "a homogenous mixture that all ignites simulatneously [sic]" simply doesn't exist. Nothing, even nuclear fuel exploding in a hydrogen bomb or the "big bang", explodes "simultaneously." IT can be very, very, very close... but can never reach that limit. But would that add to the discussion? no, not really, because everyone understands that, and you didn't mean it absolutely literally. None of that helps anyone get anywhere. Semantics, that is. Go into all the detail you want, just don't attempt to misquote others, especially when doing so for the purpose of applying a logical fallacy.
However, there is something to note, though. If the octane rating of the fuel is not "high" enough for a given engine configuration, detonation can occur prematurely (the fuel isn't stable enough for the environment). What that translates to is decreased efficiency, and in extreme cases (of time or degree), engine damage (or simply a failure to run). Nothing is gained from using fuel with an octane level higher than what's necessary to prevent premature detonation.
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
Canada's top fuel efficient cars (by class) for 2010 MetroMPG General Efficiency Discussion 3 05-09-2011 01:56 AM
Shell claims new "FuelSave" gasoline formulation increases fuel economy MetroMPG General Efficiency Discussion 32 11-07-2010 06:12 AM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
