12-17-2009, 03:29 PM
Fuel economy in the air (diesel airplanes?)
So I was reading the thread I can no longer find a while ago, and the thought has been roiling around in my mind since... Most prop planes are spark-ignition, aren't they?
Has anyone ever built a diesel prop plane?
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
12-17-2009, 03:40 PM
Moderate your Moderation.
Good question. I'm intrigued. (Actually, I'm Christ. Intrigued is another member.) Nonetheless, I'm interested to see what kind of information gets dragged up in this thread.
The Following User Says Thank You to Christ For This Useful Post:
12-17-2009, 04:17 PM
...beats walking...
...yes, diesel engines were used a lot during the 1920's-1930's:
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
...on a similar note -- I'd like to know "why?" EPA-fuel economy "guidelines" haven't also been applied (shoved up?) to the aircraft industry yet?
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
12-17-2009, 04:20 PM
i have to imagine diesels are somewhat differently affected by altitude since their compression ratio is much more critical to combustion
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
12-17-2009, 08:08 PM
What better excuse can there be to put a turbo on an engine. Although I was thinking in terms of a <10,000ft. type of plane.
12-17-2009, 09:39 PM
Intermediate EcoDriver
The German Junkers bombers of WWII were diesel-powered.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
12-17-2009, 09:42 PM
That's why they make chokes.
Design the engine to run efficiently at high alt, and at low alt, it'll probably blow up, so you either set it up to only use a max amount of fuel, which is pig-rich at low alt, and perfect at high alt, or you set it up with a choke, so that it runs as a smaller displacement engine (effective displacement) at low alt, and runs "normally" at high alt.
12-17-2009, 09:44 PM
...beats walking...
...uh, guys, two words: turbocharger and wastegate
...turbo's were usually used on ALL high-altitude engines, especially fighters.
12-17-2009, 09:59 PM
#9 (permalink)
ooo ooo ooo ah ah ah
IIRC the main concern is fuel gelling and emergency air restarts, they see some real cold conditions.
12-17-2009, 10:41 PM
#10 (permalink)
needs more cowbell
theres a couple hits for diesel airplane on youtube
(mentions Vulcan Diesel at 3:50 )
