Old 10-08-2008, 08:01 PM   #1 (permalink)
Fuel Effecient Tires
I just replaced my factory tires on a 2005 Civic Hybrid and I dropped about 8 miles per gallon overnight. I am going to take the tires back to Sam's Club but I need to find some more effecient tires....does anyone have any suggestions?
Old 10-08-2008, 08:13 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
You can look for tires that have the maximum sidewall pressure of 51psi, then you will have found some low rolling resistance tires. In other words, if the maximum pressure written (molded into the rubber) on the sidewall of the tire is 51psi, then that tire should be as good as your originals.
Old 10-08-2008, 08:20 PM   #3 (permalink)
Thanks for response...the ones I have that killed my MPG only have a 35 maximum pressure.
Old 10-08-2008, 08:46 PM   #4 (permalink)
Josepha - '08 xD
Hi,
Right, 44psi sidewall max is pretty typical, and running these at 38-40psi is a big improvement over the 35-36psi tires. Obviously, the 51psi tire can take pressures in the mid-40's and hopefully still ride okay, and improve your FE.
Old 10-09-2008, 06:34 AM   #5 (permalink)
Tire Geek
CapriRacer's Avatar
First, you should be aware that new tires will consume more fuel than worn tires - everything else being equal. This is due to more mass in the tread - and more mass generally means higher rolling resistance - all other things being equal.
Secondly, the pressure written on the sidewall of a tire has nothing to do with RR or fuel economy - except that running higher pressure helps fuel economy, but that would be true regardless of what is written on the sidewall.
The regulations which govern what can be imprinted on the sidewall are pretty vague - they only say "maximum", and different tire manufacturers interpret the regulation differently. The "max" pressure is based on a "tire standard" and that is also vague. Put another way, there are no tests that govern what CAN be imprinted, nor are there are standards that govern what SHOULD be imprinted, but the standard says that for passenger car standard load tires, the choices are 35, 44 or 51 psi - all very reasonable values for any given tire construction. DO NOT use sidewall pressure as a guide for anything other than what it says - Maximum.
Lastly, you should be aware that a tire's rolling resistance is also controlled by the tread rubber compound. Traction, wear, and rolling resistance are all part of the equation - and in order to get good RR, treadwear and/or traction have to be sacrificed. So if you see a tire with a 600 treadwear rating, you can guarrantee it will not have good fuel economy.
CapriRacer
Visit my website: www.BarrysTireTech.com
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 62 03-12-2011 02:58 PM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
