Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 01-06-2013, 08:47 PM   #11 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Originally Posted by order99 View Post
You say you tow it to the mud-are you licensed for road use, and if not could the Metro be made dual-function on the cheap? I think it would be fantastic if you could measure FE for Highway, City...and Mudhole!
His metro has no title so legal road use would be out of the question
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
Cobb (01-07-2013)
Old 01-06-2013, 09:34 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Not legal on the road and I used to drive my 4X4 to the mud park 45 minutes away and pray I make it home. Now my 4X4 will be the tow vehicle.
This vehicle will never be driven on paved roads and considered the brake trick, but went with the welded diff instead........
GeoMetroforum.com - got mpg?
Old 01-06-2013, 09:45 PM   #13 (permalink)
The Dirty330 Modder
Gealii's Avatar
45! I would want to tow my rig as well then. Only reason im considering a rig is my 9 min drive there along the most populated route there
- Henry Ford
Old 01-08-2013, 02:54 AM   #14 (permalink)
If you won't ever drive it on-road, have you never considered a Diesel swap? Either with one of those 1.1L 3cyl Perkins/Caterpillar or the engine from a side-by-side ATV such as the Polaris RZR or the Kawasaki Mule?
Cobb (01-08-2013)
Old 01-08-2013, 11:50 AM   #15 (permalink)
Hi-Tech Redneck
I never thought of using a diesel swap because the entire purpose is to keep it a Geo Metro. I also need high RPM's to keep it going through the mud and the Suzuki G10 is capable of sustaining 6-8K RPM's for extended periods of time without grenading right away. The 3200 stall converter will give me the tire-breaking power I need to turn both front wheels in the mud.
Old 01-08-2013, 01:20 PM   #16 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
How about turning into a plugin hybrid by adding electric drive to the rear wheels?
Old 02-12-2013, 07:07 PM   #17 (permalink)
Hi-Tech Redneck
BDR Torque Converters out of Buffalo, NY finally got my converter re-stalled to 3200......
Updates soon.
Old 02-12-2013, 07:52 PM   #18 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
What a scream (literally)! Thanks for the updates, what a fun vehicle.
I'm not coasting, I'm shifting slowly.
Old 02-12-2013, 08:21 PM   #19 (permalink)
Hi-Tech Redneck
Believe it or not, I started a fuel log on this thing. Getting the gas can loaded up for some fresh gas tomorrow
Old 02-17-2013, 12:29 PM   #20 (permalink)
Hi-Tech Redneck
I had the metal fabricator/mechanic we have at work do the skid plate job. We ended up removing the Turbine Tech frame brace and starting with some angle iron............
Then added the lower piece of diamond plate steel........
Then a quick test fit and tack job..............
Now he welds it all together..............
Here is where he welds the upper portion under the bumper with pre-drilled holes and welded nuts on the back side...........
Here it is bolted to the car. Only two bolts up front and the lower control arm nuts are needed to remove or attach the skid plate................
Check out all the protection when looking from the rear of the car..........
Since the frame brace is no longer the lowest part of the car, I now have 9 1/2" of ground clearance...............
All painted up and let dry over the weekend...........
check out this mess, ecomudder, geo, metro, mudder, truck boat truck
