View Poll Results: What grade gas do you use?
Regular 51 82.26%
Midgrade 7 11.29%
Premium 4 6.45%
Voters: 62. You may not vote on this poll
Old 09-03-2008, 11:56 PM   #21 (permalink)
Danger Ranger - '01 Ranger Edge 4x4
90 day: 13.59 mpg (US)
Send a message via AIM to meemooer
Well I vary between 87 and 89. Mostly 89 so thats what i voted. On 87 or regular it will ping or knock, well at idle at least The engine is whooped anyways, it'll knock and rattle on accel and burn blue/black smoke. It isn't a diesel but it looks and sounds like one
Randy
Old 09-04-2008, 12:05 AM   #22 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Johnny- Thanks for all that info. I will certainly give that a try. I never hear of using sea foam in the oil, but it sounds like a great clean out. Looks like I got more work to do.
Old 09-04-2008, 12:07 AM   #23 (permalink)
Will's Avatar
Team Chevy
Originally Posted by RH77 View Post
One gunk preventer I have on the 'Teg is a PCV catch container. It's basically an air compressor moisture collector, attached inline between the PCV valve and the intake...
That looks like a great contraption. If I can find one at a good price I may do that instead of my "redneck breather"
Old 09-04-2008, 12:31 AM   #24 (permalink)
chuckm's Avatar
Exploder - '02 Explorer xlt
Rolla - '02 Corolla ce
90 day: 44.43 mpg (US)
According to API, premium and regular gas has essentially the same BTU content (111,400 BTU/gal). Premium is needed on high compression engines because of knocking, but "normal" engines won't see any consistent benefit. Some sources say that the BTU content of premium is slightly lower than regular.
Carbon deposits in the engine, usually high mileage city driven engines, can reduce the cylinder volume (increasing compression), causing knock. But that's a pretty poor reason to spend an additional $0.30 per gallon when Sea Foam can take care of that.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 09-04-2008, 01:53 AM   #25 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
I got mine at Home Depot -- Wal-Mart may have them cheap too.
Here's the instructions on how to do it. Pretty simple, just remove the foam insert, get some screw-in hose nipple connectors (often in a package set) and hook it up. I dump mine out at each oil change.
Mr. Mullet: I'm glad a respected mechanic does the 1/3 trick as well. I heard about the cop-car water treatment, but I trust Seafoam for the lube and combustion. I generally dump it in, feather the throttle, and dump in a bunch to let it stall and sit for 5-10 minutes. I explained to my neighbors what the "fire" was all about when I first did it, though
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 09-04-2008, 02:08 AM   #26 (permalink)
2006 Matrix - '06 Matrix base
90 day: 37.5 mpg (US)
I use premium in my Matrix. The engine has a 10.5:1 compression ratio but Toyota says regular unleaded is fine due to the design of the cylinder head. It seemed more responsive when I started using premium. The deal was sealed on a couple long uphills that always required a downshift. I don't need to downshift anymore. I don't know how it's affected my fuel mileage as I started using premium before I started ecodriving.
Old 09-04-2008, 02:40 AM   #27 (permalink)
Will's Avatar
Team Chevy
Talk about overwhelming. Maybe we should all buy stock in Seafoam.
RH77-Thanks for the "how to" I will most certainly use it!
Old 09-04-2008, 04:33 AM   #28 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Not to throw a wet rag on you seafoam guys but I have to wonder about all that smoke you are pumping out. What is in seafoam and what happens when it burns? Sounds pretty nasty to me.
BTW the water injection thing works well at removing carbon build up and does not harm your engine provided you don't dump a bucket over your intake. The best thing? No extra pollution.
Something to think about...
Old 09-04-2008, 10:16 AM   #29 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
I have been drag racing fwd cars since 83 and always have looked or better FE. On EVERY car that used reg fuek, they all slowed down when I put in higher octane. Higher oct burns slower and with out having a motor designed for it, it's not needed. HOWEVER....my SRT4 requires it and when it was bought in Feb I used reg in it....got 26 mpg best at a constant 65 on interstates.....in April I started using 92-93 due to racing season and the FE jumped up to the EPA 31 rating. There was no driving problems with the reg, but power went way up in the seat of the pants area with the switch.
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
Old 09-04-2008, 07:32 PM   #30 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Metro LSi
90 day: 48.88 mpg (US)
USATODAY.com - Why use premium gas when regular will do?
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 10:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 01:22 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-03-2008 12:00 AM
