Old 03-08-2010, 05:09 PM   #1 (permalink)
Scoop - '97 Outback
90 day: 30.92 mpg (US)
Fuel Heater Question
I am experimenting with a fuel heater and am looking for some thoughts. I have put it on and am getting cylinder misfire codes. Likely from the heater making it run lean. The heater is getting the fuel to the cooling system temp, apprx 200 degrees. The idea was to get the fuel to vaporize more easily and improve the efficiency of combustion. Any thoughts on what might be going on?
Old 03-08-2010, 07:19 PM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
You could be vapor locking the injectors, which would cause a misfire. The fuel, generally, is already something like 90% atomized when it comes out of the injectors anyway, which is part of the reason fo a high-pressure fuel system. (Higher pressure atomizes the fuel better). The way to attempt what you want to do is actually to just heat the intake air, because as you're finding out, you can't vaporize the fuel completely unless you have injectors that can either handle vaporous fuel, or extreme pressures required to keep the fuel liquid at that temperature.
If you want to continue the experiment, try monitoring temps of the fuel and starting out at normal temp, then heating the fuel slowly until you start getting the misfire code again, then back off the heat a bit.
The Following User Says Thank You to Christ For This Useful Post:
BArmstrong (03-08-2010)
Old 03-09-2010, 03:36 AM   #3 (permalink)
I was cleaning some injectors with my homemade vacuum injector cleaner and carb cleaner not too long ago. I realized the gasoline present inside the intake manifold is probably boiling under normal operating temps, this was after I witnessed the carb cleaner exiting the injector went from a spray pattern to a mist once the vacuum exceeded 15 in/hg
Old 03-09-2010, 08:11 PM   #4 (permalink)
Steve - '92 Festiva
It's a little different in an intake manifold... engines aren't really ever under vacuum, because there is always air going in. The "vacuum gauge" is just giving you an idea of how much pumping is going on, or what you would feel/see if air were not present in the manifold.
Under conditions of true vacuum, yes, the fuel would boil and vaporize instantly, and it may partially do that in the intake manifold, but because of the quantity of fuel and the inflow, it doesn't happen fully, which can be evidenced by burn pattern analysis, which shows that fuel actually pools around the crevice areas of the combustion chamber, such as the gap between the piston and the cylinder wall above the top compression ring.
Old 03-10-2010, 12:52 AM   #5 (permalink)
True vacuum? you mean continuous vacuum?
I would expect to see a cyclic vacuum taking place (under lower than ambient manifold pressures), similar to a sine wave; the gauge should be an average pressure reading, but then again the velocity of the air at the injector port itself makes it more complex.
Old 03-10-2010, 01:01 AM   #6 (permalink)
Steve - '92 Festiva
EDIT: This is "as I understand it". I welcome other input, suggestions, or data which suggests otherwise.
No, I mean true vacuum. The vacuum in the manifold is only readable because of the velocity of the intake flow, which is why the vacuum reading in your manifold actually could change depending on where you plumb the line, although most gauges won't register the change (which is going to be fractional, at best).
Vacuum can only truly occur in a sealed container which does not contain atmosphere, which means that since an intake manifold constantly has some amount of air in it, there is no actual vacuum, only a reduction in ambient pressure of the volume of air present.
If you checked the vacuum at each port of each cylinder, you would see the cyclic effect you're suggesting, but only for milliseconds per revolution, right before the air has a chance to react and begin moving into the cylinder.
I guess the point is that induction is not vacuum, by definition.
The flow of air through the manifold would prevent the pressure of the fuel from being reduced to the point where it boiled, except maybe for a few milliseconds until it actually got to the airstream, at which point it would instantly become liquid again.
Interesting to note -
The largest percentage of the noise from submarines in motion comes from steam, which is produced in bubbles which follow the trailing edges of the propeller. The bubbles "pop", which creates the noise signature that other submarines and radar/sonar systems recognize as a submarine.
The bubbles are a low-pressure zone in the wake of each prop blade. The pressure is low enough that water boils instantly in that area, then as it cools via the surrounding water and pressure change, it changes back to liquid and the bubble formed makes a pop noise.
Old 03-10-2010, 01:20 AM   #7 (permalink)
Pure gasoline boils at a much lower temperature, as low as 100F. I'd keep it at about 150 tops especially if I was getting misfire codes due to vapor lock.
Old 03-10-2010, 04:34 AM   #8 (permalink)
How exactly are you defining "vacuum", by the technical definition - space absent of matter? The term seems to be tossed around loosely these days. A perfect vacuum isn't possible on earth, questionable even in deep space. Maybe I have been wrong for using the term "vacuum" for any absolute pressure less than one atmosphere.
Old 03-10-2010, 08:30 AM   #9 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...to "pull a vacuum" = to have an absolute pressure less than one atmosphere.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 03-10-2010, 10:12 AM   #10 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
I think there are alot of other things you can do to get better mileage
Try hypermiling. Driving style often makes up for more than 50% of the gains on here
Check that your car is tuned up Filters spark plugs oil change Etc.
And max ur tires up to full pressure for lower rolling resistance those all will likely help more than just a fuel heater will
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Glossary Take II SVOboy Forum News & Feedback 25 03-05-2012 11:53 AM
Canada's top fuel efficient cars (by class) for 2010 MetroMPG General Efficiency Discussion 3 05-09-2011 01:56 AM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
