Old 07-22-2017, 09:46 AM   #21 (permalink)
ar5boosted's Avatar
Originally Posted by teoman View Post
ar5boosted, if that were the case, then then his exhaust must have been smelling of raw fuel. Or are you saying that it combusts later without providing useful work just heating the exhaust.
Less fuel is being sprayed, but the amount of fully vapourised fuel (the part that will combust and explode) is the same as the old injectors. Increasing fuel-economy.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
Old 07-22-2017, 10:51 AM   #22 (permalink)
MPGuino Supporter
t vago's Avatar
The Karen-Mobile - '05 Dodge Magnum SXT
Team Dodge
90 day: 26.72 mpg (US)
Fiat Dakota - '00 Dodge Dakota SLT RWD Quad Cab
90 day: 16.67 mpg (US)
The Red Sled - '01 Dodge Durango SLT 4WD
90 day: 16.96 mpg (US)
It also creates soot that sticks to the exhaust insides.
The Fiat Dakota
The Karen-mobile
The Red Sled
Old 07-22-2017, 09:28 PM   #23 (permalink)
Terky - '99 Toyota Tercel CE
90 day: 55.71 mpg (US)
I just did this mod today.
Replaced a set of 1999 single-pintle injectors in the Tercel with 12-hole injectors from a 2011 Yaris in the junkyard.
Not quite plug-and-play. I had to cut and solder the new wiring connector to the Tercel harness. At least the injectors fit in the rail without too much difficulty. Car runs just fine and no leaking fuel.
The Yaris injectors I am given to understand are ~200 cc, whereas the Tercels were 176 cc, so it will run rich until the trim knocks it down a bit.
I'm interested to see the effect on my next tank though
The Following 2 Users Say Thank You to jonzobot For This Useful Post:
t vago (07-22-2017), taco (08-08-2017)
Old 07-22-2017, 09:42 PM   #24 (permalink)
MPGuino Supporter
t vago's Avatar
Team Dodge
That's about a 13% increase, so your engine computer's trim should be able to adjust for it.
Very much looking forward to seeing your results, too.
The Fiat Dakota
The Karen-mobile
The Red Sled
The Following User Says Thank You to t vago For This Useful Post:
jonzobot (07-24-2017)
Old 07-22-2017, 10:04 PM   #25 (permalink)
Kristin's Impala FFV - '10 Chevy Impala LT
90 day: 25.5 mpg (US)
XFE Coupe - '09 Chevy Cobalt XFE
90 day: 35.54 mpg (US)
Kt's Cobalt - '10 Chevy Cobalt LT
90 day: 28 mpg (US)
Penny's Rogue - '15 Nissan Rogue SL AWD
90 day: 28.05 mpg (US)
Cam's Rogue - '11 Nissan Rogue SV AWD
90 day: 24.7 mpg (US)
T vago do you have a 2 piece louvered grille, on side mostly open other half closed. I've been seening that car(grille) for a while years on 151, saw it Friday just just north of Amana 4way stop 5:20 ish. My eyes never get much past looking at the grille but think it might have been a magnum and maybe dark grey. Used to see a Neon? with a grille block on the road occasionly.
13% increase might also let you run E85 without a CEL.
Old 07-24-2017, 12:58 AM   #26 (permalink)
So I drove 250km on the highway today.
This might be placebo, but my first impressions are that the engine feels a lot more smooth and quiet. All good signs - even if the fuel efficiency doesn't change at all, a smoother engine can only be good for wear and longevity.
Power did not really seem noticeably different, though my butt dyno isn't all that good.
Old 07-24-2017, 04:22 AM   #27 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
90 day: 56.86 mpg (US)
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Jonz expect your economy to be down this tank, because the trims will take several drive cycles to fully settle down. The only thing I would be worried about is, on cold starts when in open loop, the car will be running much more rich, and burn more fuel.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Old 07-24-2017, 04:28 AM   #28 (permalink)
I believe it learns that too. It uses closed loop data to adjust the open loop behaviors.
Speaking of the cold engine ove fueling issue. Could that not be overcome? Or would the engine stall.
Old 07-24-2017, 10:12 AM   #29 (permalink)
90 day: 28 mpg (US)
I'm pretty sure the LTFT (long term fuel trim) carry over to Open loop to compensate for variations in fuel. Generally LTFT can go about 20 either way without a CEL. This is why if you put in to much ethanol you will get a CEL, even if the injectors are keeping up. With 13% larger injections your LTFT will be a negative with regular gas but probably still in the OK range.
The Following 2 Users Say Thank You to roosterk0031 For This Useful Post:
ECONORAM (08-08-2017), jonzobot (07-24-2017)
Old 07-24-2017, 11:11 AM   #30 (permalink)
MPGuino Supporter
t vago's Avatar
Team Dodge
Yah, my grill is half open like that, and that was about the correct time I left work. So, yah, you probably saw me.
This morning, got a current trip figure of 29.0 MPG.
The Fiat Dakota
The Karen-mobile
The Red Sled
ksa8907 (07-24-2017)
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
