Old 08-14-2017, 02:45 AM   #51 (permalink)
MPGuino Supporter
t vago's Avatar
The Karen-Mobile - '05 Dodge Magnum SXT
Team Dodge
90 day: 26.72 mpg (US)
Fiat Dakota - '00 Dodge Dakota SLT RWD Quad Cab
90 day: 16.67 mpg (US)
The Red Sled - '01 Dodge Durango SLT 4WD
90 day: 16.96 mpg (US)
Originally Posted by Galane View Post
For some V type engines, changing the way the fuel rails for each bank re connected can make a significant difference.
One example. On the 2004 and earlier Dodge Dakota with 4.7L OHC V8 the fuel enters in the middle of the left rail. The front of the left rail is connected to the front of the right rail. Right rail fuel, especially to the rear two injectors, has much more time to get heated up. There are two fixes for this, one fairly easy one not so easy.
The not so easy method involves buying more injector rails and a second cross connection pipe then modifying the rails to connect at both ends.
The easier method involves installing a T into the fuel line then running a high pressure hose across to the fuel pressure test/bleed fitting in the middle of the right rail. Nothing has to be removed except for disconnecting the fuel line so it can be cut for installing the T.
Either mod evens out the pressure and temperature of the fuel. Dunno if anyone has done both mods.
Some who have done one of those mods say they've gotten measurable HP and torque gains at the rear wheels on a dyno, as well as better MPG.
I did the not-so-easy fuel rail mod. Worked wonders.
The Fiat Dakota
The Karen-mobile
The Red Sled
The Following User Says Thank You to t vago For This Useful Post:
ECONORAM (10-03-2017)
Old 08-14-2017, 08:52 AM   #52 (permalink)
Details please!
Old 08-14-2017, 09:19 AM   #53 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.48 mpg (US)
Tiptoe - '03 Honda Civic Hybrid
90 day: 48.9 mpg (US)
90 day: 48.43 mpg (US)
Originally Posted by jonzobot View Post
Just to be clear, my plan is only to increase to the voltage of the fuel pump to help maintain fuel pressure to its factory spec.
Is there not a separate fuel pressure regulator that you could adjust?
Take it easy
Old 08-14-2017, 01:57 PM   #54 (permalink)
MPGuino Supporter
t vago's Avatar
Team Dodge
Details please!
Well, for starters, I apparently am the first to have documented this not-so-easy method, waaaaaay back in June 2010.
Details are here: Dakota-Durango: Does anyone here use fuel rail cooling?
I remember coming up with the idea to do something about fuel temperatures after dealing with yet another instance of heat-soaked lack of response. Somebody else in that thread actually mentioned feeding the two banks independently, as a possible way of equalizing fuel temperatures.
Apparently, Summit Racing now states they do not recommend the Twist-Tite stuff for fuel use. I therefore recommend fabricating the fuel hoses out of braided nylon hoses and hose ends.
The Fiat Dakota
The Karen-mobile
The Red Sled
ECONORAM (10-04-2017)
Old 08-14-2017, 02:31 PM   #55 (permalink)
Just to clarify, your existing injectors can't be flow matched. Companys who sell matched sets buy large amounts of the same injectors, test them all, then make sets based on the results. They don't change the flow characteristics to accomplish this. I'm not aware of anyone who sells matched sets of injectors as small as yours. This is a great resource for understanding injectors a bit better.
The Following User Says Thank You to greasess For This Useful Post:
jonzobot (08-15-2017)
Old 09-04-2017, 01:17 PM   #56 (permalink)
Lone Ranger - '97 Ford Ranger XLT step-side
90 day: 28 mpg (US)
t vago.... How did you find a comprable fuel injector? I know this is a rather open ended vague question, but did you just find the parameters of your stock injectors and then check RockAuto one by one until you found what you wanted? I have wanted to do this swap on my Ranger for a long time but am completely uneducated on the technical stuff. I can turn a wrench really well, but don't want to make any mistakes in sizing. When I look on RockAuto I can't tell how many holes the injectors have. I still have the stock single hole ones so even a 4-hole would be an improvement. I would love more holes if possible. Also isn't there a diference in high impedance and low impedance injectors. Not sure which I have (low I think) but I'm sure they aren't compatible. Any insight you have would be great.
Thanks
Old 09-04-2017, 02:12 PM   #57 (permalink)
90 day: 28 mpg (US)
I would love to swap my OEM ones like these
More Information for MOTORCRAFT CM4779
with these
More Information for STANDARD MOTOR PRODUCTS FJ462
But the shape is a bit different and the electrical connection also looks different. There may be electrical adapters available but I don't know about the shape and length. The OEM ones look shorter than the other ones.
Old 09-05-2017, 01:48 AM   #58 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
Does anyone like Injector Dynamics match small injectors at multiple points? If I were to upgrade an older engine from single point, I would probably be flow balancing the rest of the engine.
Actually I shudder to think, on a 302HO inlet manifold flow @28" can vary by 25% runner to runner. Assuming that makes a 10% dynamic airflow difference and the injectors at low pulse-widths can vary by another 10%... that makes for a potential air-fuel ratio mismatch of 22% or so. Which with a target of 14.7:1 is a range of 17.9-11.4:1
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
Old 09-28-2017, 01:13 PM   #59 (permalink)
Supra - '88 Toyota Supra
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 18.59 mpg (US)
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
I'm interested in putting 12 hole injectors on my 99 f150 4.6 I know the stock is 19lb but not sure on body or electrical connector any idea on what might work?
Old 10-04-2017, 12:24 AM   #60 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
I knew AIRRAM had insulated his fuel rails, but I didn't think about the advantages. My 07 has 4 O2 sensors and 2 cats (not sure if that's how your 00 is), so I am curious to see how just some insulating tape might change fuel economy...
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
