Old 10-08-2017, 03:13 PM   #1 (permalink)
Reducing NVH
Anyone have any tips to reduce NVH in your CRX's? I'm running a bone stock 91 CRX HF and am rebuilding this car with MPG and daily drivability in mind. The car is pretty loud and was hoping people had tips on some low hanging fruit to reduce noise and vibrations to the cabin. It seems the POLY inserts in the rear engine mount were a bad idea though, lol, which is a shame because the car becomes much more responsive on the road.
Old 10-09-2017, 09:53 PM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Some of the thin dynomat will help without adding too much extra weight to the car.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 10-11-2017, 10:21 AM   #3 (permalink)
Where are the best places to put it?
Old 10-11-2017, 11:12 AM   #4 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
When I still had it, my Dodge Caravan appeared to be a collection of parts flying in close formation, and none were especially respective of each others' personal space. It was a rattly, squeaky disaster.
I spent a couple of hours one weekend before a big trip, taking every interior panel off and reinstalling it with a thin piece of leather under each contact point. I got the leather from a messed up jacket someone was throwing away, so my entire investment in the project was time. It helped a lot, but it wasn't everything. An old CRX should have some opportunities for you to find attachment points and make necessary modifications.
The Following User Says Thank You to elhigh For This Useful Post:
Daschicken (10-18-2017)
Old 10-11-2017, 04:32 PM   #5 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I think Dynomat works best on larger thin metal panels. Your CRX has some tar-like matting already. I usually scrape the factory stuff out because it's heavy. I don't notice a difference in noise.
My Wagon with a gutted interior is really loud inside. It's mostly tire noise. Insulating the floor and wheelwells should help.
I want to make my CRX a lot quieter than my Wagon without adding much weight. Please post any noise reduction results here.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 10-11-2017, 08:45 PM   #6 (permalink)
Spaced out...
I'd do was gasoline fumes mentioned about dynomat on the wheel wells and floors and add that a piece on the roof will help too. Some NVH can be address by just making things tighter like elhigh did in the interior but also making sure exhaust hangers are tight too....at 2000rpm my Focus exhaust rattles like crazy in the cold. New Weatherstripping for the trunk and doors will help reduce wind and road noise too if yours has seen better days.
-Mike
Old 10-11-2017, 08:49 PM   #7 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
When you're next to a hard acceleration truck and crack open a window, notice that even the tiniest opening lets in 90% of the noise. Start by sealing up any gaps where factory grommets and seals have degraded over the years.
Second thing I realised about sound proofing is that you'll always be limited by the car's glass, most of the noise in my Renault comes in through the large areas of glass, sound proofing the rest of the car is of little value, unless you have a specific problem.
Old 10-12-2017, 08:14 AM   #8 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
My Wagon got noticeably louder when I removed the passenger's seat. I'm not sure if the seat was blocking noise from the rear tires or absorbing the noise. Maybe both.
You have poly inserts in the rear engine mount only? Can you take them out and try stiffening the front mount instead?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 10-13-2017, 12:50 PM   #9 (permalink)
The front mount isn't there anymore. I changed my front crossmember to an aftermarket unit and there's no mount there for the motor.
I think i may make an underbody panel for aero reasons and try and seal it well from bumper to bumper. I'm hoping this will reduce some noise as well.
Old 10-13-2017, 02:47 PM   #10 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
I was thinking about trying to dynamat the floor and up the firewall, then realized good floor mats would essentially do the same thing with almost 0 effort. Got some universal mats from weather tech, and thought they helped
