Old 10-12-2009, 07:19 PM   #1 (permalink)
EcoDriver
BlueCivic - '97 Civic LX
90 day: 33.85 mpg (US)
Fuel injector puller
I fought with pulling a bad injector for about an hour twisting and pulling - actually just tearing up fingers.
Small channel locks were the key!
You just have to be careful not to snap off the top.
Just wanted to share that tip.
Old 10-13-2009, 12:39 AM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Push it down with your thumb as tightly as you can muster, spray in some WD40 or even just use some gas (not as effective), then work it with your fingers up and down in the direction that you'd be pulling it out.
Often, I'll get a cut pigtail from the same type of injector and use that as ballast to pull it from more than one angle.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
