Old 09-30-2009, 03:13 AM   #1 (permalink)
Fuel sock problem: cheap fix?
Hey, I was wondering if anyone knew of a "redneck" method of repairing a fuel sock without having to splurge for a new one.
My Contour will have the fuel supply cut-out during hard right turns and/or acceleration whenever it has less than 1/4 tank. The obvious solution is to never get below 1/4 tank, but this gets annoying, and tankering around 5gal/30# of unusable fuel isn't optimal for FE purposes.
Short of buying a new fuel sock, is there a way to make the existing one function better? My pump/sock assembly is easy to get at...just remove the rear seat...but I'm not inclined to spring for a new sock. If I can find a way to patch the old one, I'd give it a try.
Old 09-30-2009, 06:19 AM   #2 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I don't understand the nature of your problem. "Patch"- is there a hole in it? Is it not working because it's not positioned at the bottom of the tank? Can the line to it be bent downward to reposition? Is it plugged? Why would a new one fix it?
Old 09-30-2009, 10:00 AM   #3 (permalink)
Sorry...I just had been told that the fuel pickup (sock) was the cause of my fuel cutting out at low levels. I was wondering if the existing one could be removed and repaired vs. buying a new one.
I just priced them, though, and am embarrassed at how little they cost ($17). Looks like I'll be buying one
Old 09-30-2009, 01:46 PM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
They are pretty cheap. But I agree with Frank, it doesn't sound like that is the problem. I would more suspect a broken baffle in the tank. That is supposed to keep a supply of fuel around the pump so it does not slosh around easily and cut out.
If all else is ok, and your gauge is accurate, I would keep the extra fuel in the tank instead of running it down and shortening the life of the fuel pump. I'd find it unlikely that the fuel savings from dropping less than 30# of fuel would be greater than the cost of a new fuel pump.
Winter daily driver, parked most days right now
Summer daily driver
Old 09-30-2009, 02:58 PM   #5 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 39.53 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 23.7 mpg (US)
There is a TSB for these cars that deals with the fuel gauge not reading below a 1/4 tank. Has to do with welds in the tank interfering with the float. Maybe you are actually low on fuel? Rename the attached file to have a .pdf extension instead of .xls extension. For some reason the forum has an extremely small limit to the file size for .pdf documents.
moorecomp
Mancelona, MI
Old 10-04-2009, 09:42 PM   #6 (permalink)
Funny Jeeps have the same issue... The in-tank sock and pickup tube get crimped by the tank aging and suposedly from alcohol. The plastic the tank is made of shrinks slightly when it contacts alcohol and O2, as well as the pickup tube and the "Sock". I'm taking mine apart this week to see if its true... I have a fuel delivery gremlin that is very temperature and angle dependent...
It will be interesting...
Dave
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
NASCAR "Advanced Fuel Economy Dodge"; NASCAR Prius model coming soon! MetroMPG The Lounge 9 07-14-2009 02:35 PM
NASCAR "Advanced Fuel Economy Dodge"; Prius branded model coming soon! MetroMPG The Lounge 0 07-08-2009 09:20 AM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 03:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
