10-13-2015, 05:38 PM
#41 (permalink)
Originally Posted by RustyLugNut
All because I bought plans from the back of Popular Mechanics for the Pogue 200 mpg carb and other wacky devices.
I just saved up for X-ray specs from the back of Boys' Life. Man, was I disappointed! I could not see inside my Christmas presents!
10-14-2015, 01:50 PM
#42 (permalink)
Master Novice
Originally Posted by Frank Lee
There's more opportunity for higher fe in the hills, especially with a stick.
Can be. I struggle with hills, high-octane commuters climbing up my tailpipe and a failed IMA pack. But I do okay.
10-14-2015, 06:49 PM
#43 (permalink)
P&G on the flats stinks. On the hills, much better.
11-12-2015, 08:32 PM
#44 (permalink)
Aero Deshi
I rock the hills, a few years back I was working in Seneca SC with a 25 mile commute including a bunch of hills, I consistently got over 40 mpg for 5 tanks averaging 55 mph or so with about 1/3 the distance rolling motor up coast down hills. My LT Average is 34.8 and never better than 36 mpg in flat ol Florida. Vroom.
12-08-2015, 06:24 PM
#45 (permalink)
Fuel Vapor Carbs
Here is a book I got though Lindsey Publications,advertised in the back of Popular Science or Mechanix Illustrated.
It has the patent illustrations for about a dozen fuel vapor carbs,and testimonies and anecdotal evaluations.It was about $12 (US).
12-08-2015, 07:25 PM
#46 (permalink)
I am trying to build one, a real one.
http://ecomodder.com/forum/showthrea...tor-32977.html
Just need to put it together.
Got any pointers?
I only expect mine to help fuel economy in cold conditions.
12-09-2015, 06:04 PM
#47 (permalink)
pointers
Get a push car and driver.Each time you drive,you'll need a push up to 35-mph so you can start the car and drive at 35-mph.
When your forced to stop at a sign or traffic light,keep that push car close by,as you'll need it each time you start off.
Don't expect to drive any speed other than 35-mph.That's all these carburetors will allow for.Seriously!
12-09-2015, 07:43 PM
#48 (permalink)
That is kind of what I was thinking and that is what word of mouth has always been on them.
Tiny single bore, no accelerator pump.
I am just trying to put a 4bbl edelbrock on top of a coolant warmed carb heater plate.
12-12-2015, 12:48 PM
#49 (permalink)
carb heat
In the 1960s,GM had thermostatically-controlled exhaust heat diverters built into their intake manifolds.
My CRX also had carb heat via hot coolant circulation and also t-stat controlled hot air riser into the air cleaner housing.
