Old 04-24-2010, 11:39 PM   #41 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by sc2dave View Post
But what if you have a carbed engine? I wouldn't consider them "very efficient"
A carb'd engine can be just as efficient or more so than a injected engine (mpg wise), it depends on who tuned it and what load you are running, I am not saying a carb is more efficient across every throttle position, but it can outdo EFI especially if you lean it out a bit which is rather difficult on EFI.
Old 04-25-2010, 07:42 AM   #42 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
With my 4x4 4 banger EFI TB Nissan I have been able to lean out the mix by adding resistors (I use small pots) to the cylinder head temp sensor and the throttle position sensor...and can control these from the cab. Did not see any mpg gain from doing this...and do see a loss of power if leaned out too much. Fairly simple to do...IF you know what to do.
* There are some various writeups on how to do this...including one I did.
Will probably try to test this leanout with a vapor injector (FA2000 type) sometime soon.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Old 04-25-2010, 04:48 PM   #43 (permalink)
rmay635703's Avatar
You don't want the motor running lean continously and generally you only want up to approx 16.7:1 when holding steady state or decreasing speed, not during acceleration. You would have to rewrite your ecu./ecm program to accomplish this, similar to GMs euro cars.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Summer mix fuel changeover brucepick EcoModding Central 11 04-19-2008 09:32 PM
