10-29-2013, 06:33 PM
#331 (permalink)
2-years
Thanks Bam,I'll lament its demise without ever seeing it in the flesh.
It reinforces my complete lack of expectations as to ever seeing a consciousness shift within the USA within my lifetime.
10-30-2013, 04:39 AM
#332 (permalink)
Confirmation bias. Things are getting better. [OK, I looked at your comment at #318. Not everything is getting better, just things in general]
The link I posted has [undated] reader comments the are all buy/sell opportunities.
I started a teardrop thread that sort of went nowhere, but the chassis would work well under the 1955 German body.
skyking -- I could see a New Beetle where the hatch is removed and replaced with a pyramid consisting of 3 triangular portholes and a 5th wheel hitch up high over the rear axle line.
12-05-2013, 10:04 PM
#333 (permalink)
The single wheel trailer seems like it would make gap sealing a lot easier: only one axis of movement, rather than 3 to deal with.
Speaking of "the little Beetle that could" and 5th wheel hitches...
The Following 5 Users Say Thank You to Hugh Jim Bissel For This Useful Post:
12-05-2013, 11:24 PM
#334 (permalink)
T-100 Road Warrior
Pssst...
http://ecomodder.com/forum/showthrea...ler-26997.html
Gitting closer to fabbing up the gap covers...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
12-06-2013, 04:51 AM
#335 (permalink)
12-28-2013, 02:39 PM
#336 (permalink)
new candidate for full boat tail
Reason: add yet another example
12-29-2013, 11:51 AM
#337 (permalink)
That's an awfully expensive turbine on a harbor Frieght trailer. ???
12-29-2013, 01:16 PM
#338 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
my thoughts.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
12-29-2013, 08:34 PM
#339 (permalink)
And where is the propane?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
12-30-2013, 12:17 PM
#340 (permalink)
Why a microturbine? They are awfully inefficient. Generally 14,000+ BTU/kw output. Gas engines run around 10,000 BTU/kw. Gas engines will run on propane just fine.
Aero-trailer? Yes!
Micro-turbine trailer? Not so much.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
