Old 12-03-2009, 01:28 PM   #1 (permalink)
Golden SE-R - '05 Altima SE-R SE-R
90 day: 30.06 mpg (US)
Gas Mileage Down with the COLD---WAI?
I've noticed now that it is winter and temps are getting below freezing that my MPG's are taking a serious hit the first 5 or so minutes. Since my typical commute to work is only 8-10 minutes it's killing me! I'm thinking about swapping out my old filter for a Short RAM Warm Air Intake---will this help, even if it's just a bit? Any other ideas---synthetic oil? What weight?
Old 12-03-2009, 01:40 PM   #2 (permalink)
Signature Check!
Old 12-03-2009, 01:52 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'd definitely suggest synthetic, in the engine and transmission. I've been running synthetic engine oil for a while, but I changed over to synthetic last winter and the car noticeably would coast farther when cold.
As for the intake, I'd just grab some of that flexible metal ducting for your dryer and route your intake over to your exhaust. Its quick, easy, cheap, and you can stick with your stock plumbing and filter.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Worst City gas mileage ever jasonck08 Hypermiling / EcoDriver's Ed 29 08-18-2009 09:00 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
