Old 02-20-2008, 04:31 PM   #11 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Anecdotally... Even cracking the windows open severely disturbs flow over the back of a car... Not such a big deal when you're stopped But to determine if the aero hit is cost effective, you'll have to test yourself with instrumentation.
Challenge me, or correct me, but don't ask me to die quietly.
Old 02-20-2008, 04:58 PM   #12 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Sounds like something isn't right. You shouldn't be getting that low of mileage if your not driving aggressivly.
Old 02-20-2008, 05:18 PM   #13 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Thumbs up
No roads, thanks for your service.
gas prices are cyclic and they will go back down.
do you have a pic of your truck maybe we can see something amiss.
i am thinking something is not right about your truck.
i don't believe the dealer, i hope i don't hurt anyones feelings.
any info like average speeds, weight, differential ratio, did you buy new or used etc.
a ton of driving tips on this site, i am confident if your willing embrace, the advice you can increase your mileage considerably. there are people on this site getting 20MPG with F250's, that is a 4100# vehicle. and you can too, if you like the game we play.
just one example tire pressures, we run at the max. on the sidewall.
also check alignment, brake drag etc
hang in there, diesel. USAF71-74
Old 03-04-2008, 05:37 PM   #14 (permalink)
H4MM3R's Avatar
Welcome to the community.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Americans get serious about using less gas Frank Lee The Lounge 21 02-29-2008 05:45 PM
News: Canadian gas prices may pass $1.30/L ($4.93/US gal) in months with $100 oil MetroMPG General Efficiency Discussion 5 01-04-2008 02:08 PM
As Vancouver gas prices soar, so does transit use MetroMPG Alternative Transportation 0 12-01-2007 11:26 PM
