Old 04-12-2013, 10:00 PM   #1 (permalink)
The Stang - '89 Ford Mustang LX Hatchback
90 day: 21.04 mpg (US)
Gas saving is like a game to me :D
So i used to floor my honda civic everywhere i went. when i kept losing "Races" i stopped wanna be racing and then realized my car is meant to be a gas saver, so i filled up and got 35 mpg 95%hwy other is city
that was mixed tires, low psi, bad control arm bushing, and two back tires
then with better driving habbits i got better and better mpg
saw 36 and 37 then 39.
anyways little by little i been fixing my civic up and recently i just scored 42mpg!!! got 325 miles and the gas autoshut off at like 7.7 i still need to replace my bumper and hood. and a the power steering pump.
this is freaking awesome.
anything else i can do to get better mpg? low cost/free cost
its a honda civic 95 dx sedan, 144,440 miles on it 5 speed
oil change is due soon, thinking of replacing the air filter,
Sorry, new users are not permitted to post links in their signatures.
Old 04-12-2013, 10:30 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Gotta savd up for a scangauge!
It's like a LIVE video!!!!!!
see ling in my sig
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Flakbadger (04-13-2013)
Old 04-13-2013, 04:26 AM   #3 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
-Pump your tires up! Mine are sitting at 42 PSI right now, sidewall maximum is 44.
EDIT: Make sure you check your specific tires for their sidewall maximum BEFORE you inflate them! Overinflating a tire is extraordinarily dangerous.
-Make your next oil change synthetic! It costs a bit more, but believe me it pays off. Car runs smoother and you can wait a lot longer to change your oil (Unless you have an oil leak, in which case the synthetic will just run right out of it!). The added benefit is less resistance in your engine parts, making better MPG.
-Definitely change your air filter if it's time. No reason not to.
EDIT: Unless you meant change it to a cold-air intake, in which case don't. It has been proven many times over that they do not increase efficiency except at wide-open-throttle, and how often does an eco-driver do that?
-While not technically "low cost," a Scan or Ultra gauge is an incredible tool and will most assuredly pay for itself over time, especially since you can transfer it from vehicle-to-vehicle.
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
Old 04-13-2013, 04:31 PM   #4 (permalink)
The PRC.
+1 for the tyres, +1 for the SG2 or UG. +/-1 fr the oil - check your specific engine can run on fully synth first - some engines prefer a mix.
Technique will get you the most benefit, and a SG2/UG will help you there.
Old 04-14-2013, 05:13 AM   #5 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
see ling in my sig
I think SG II won't work with 95DX, so probably MPGuino would be a better option.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
