Old 07-25-2009, 07:03 AM   #1 (permalink)
Question GE 48V dc motor heat sensor
hi guys,
Your help has been invaluable....! Just got motor back from rebuild...looks great...except..I need your help again ASAP so I can get the motor installed this weekend....
There are two black wires coming out of the motor housing, that probably were attached to a sensor, which was missing when they took the motor apart? (it has been apart before judging by what they found inside)
I labelled one of the black wires as going to Blue/white as I disconnected everything before removing the motor.
I'm assuming it is a heat sensor to switch on the fan?
if so...what do i do now? Can you provide a schematic ( motor details listed in previous post) or hopefully tell me what type of sensor, where to get it locally, and where does it mount inside the motor?
I assume it is fairly generic and that I can pick one up at an autoparts or electronic shop. Can I run the fan continuously until I can find the sensor if thats what it is. Also if so, do I just connect the ends of the two wires together inside the motor to run the fan?
Hope this is enough information for you to help me.
Old 08-09-2009, 03:10 AM   #2 (permalink)
problem solved guys!
It appears that the motor was wired to run continuously after a new controller was installed....motor is back together and hope to report being mobile very soon....
cheers.
Electrique
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
Best spark plugs / wires with FE in mind? noopy7 EcoModding Central 12 10-29-2010 04:18 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 07:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
Perhaps honda specific: Will a code 41 (o2 sensor heater) tank my mileage? SVOboy Off-Topic Tech 13 08-04-2008 10:35 PM
