Old 03-24-2010, 12:54 PM   #1 (permalink)
Gear Vendors + old Diesel = 24 mpg
Got a Gear Vendors installed on my 89 Dodge, and so far the results are pretty good. Got 24 mpg yesterday at a constant 65 mph (including hills) and I'm pretty sure a few tires were 10-15 psi low. Also had to race a few imports who thought they could keep up with the old diesel
I plan on airing all the tires up to about 60psi and seeing what it'll do at 55-60mph on flat ground soon. Hard to get a good fuel economy test here in Los Angeles, all the aero mods and coasting in the world won't do a thing if you're stuck in 15 mph traffic for two hours.
1982 Chevette diesel 36 hp at the wheels, best 59.6mpg.
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, really bad fuel economy.
The Following User Says Thank You to JQmile For This Useful Post:
DieselFan (09-01-2011)
Old 03-24-2010, 04:02 PM   #2 (permalink)
Hyperlurker
daring4's Avatar
DD - '87 Fiero GT
90 day: 32.64 mpg (US)
D-max - '04 Silverado Ls
Notch - '65 1500 S
What load range tires are you running on that dodge? I run 75 psi most of the time in my pickup, load range E. I used to have a daily driven 612 hp(crank) 63 Nova that got a solid 3 mpg!
Old 03-24-2010, 06:08 PM   #3 (permalink)
The power to MPG thing is what gets me about diesels. Once a get a bottle heater for my nitrous bottle, I think I'll crack 500 hp at the wheels, and that's still w/o a lockup converter, so my efficiency isn't the best. But I can get over 20 mpg with the same vehicle! I have E load range tires also, but LA freeways can be pretty jarring cause they're so beat up from the big trucks, so I usually run the tires pretty low.
Corvette V8 diesel conversion - 40 mpg (US) avg. MetroMPG EcoModding Central 91 05-11-2011 11:50 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 7 09-01-2009 02:44 PM
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 11:51 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
