Old 08-20-2009, 10:54 PM   #1 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Gen II Prius Life Expectancy
I know the question has been asked before, but time has passed...
We're looking for a replacement for Teggy, but instead: 4-doors, newer, and efficient (the preference is for it to remain a hatch).
I recently spoke to the owner of an '06 with about 100K miles (and who just bought a Gen-III). The consensus is that the battery pack is bench-tested to 150K miles (beyond the 100K warranty).
Most affordable and easily found models are at the 100K mark. Herein lies the problem: we are keeping cars for a while now (6-8 years+). That could mean 120K miles or more on top of the existing clock.
So, Hybrid Experts out there, buy a used one, or pay a bit more for a new model? What about the new Insight in comparison? If the budget permits, these cars are considered -- otherwise, it's going to have to be new Honda Fit.
Despite the weight addition of these items, it has been decided that the following are required: side/front airbags, ABS, A/C, automatic (not entirely my choice) and a good crash rating -- otherwise, I'd look at a older Civic or similar.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 08-20-2009, 11:01 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
The Toyota packs have held up a lot better than the 1st gen Insight and even gen1 Civic packs. The hybrid synergy drives have a very aggressive control over what happens to them to avoid any damage to the battery and to extend life. I fully expect mine to last me to 200k+ miles. However, I specifically did look for one with as low of mileage as I could find. But, that is more because we drive around 30k miles a year.
The Following User Says Thank You to Daox For This Useful Post:
RH77 (08-20-2009)
Old 08-20-2009, 11:03 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Since you have to have an automatic, that'd steer me to the Prius by default.
I'd say start searching now for a gen 2 Prius, and be prepared to buy when a good one crops up (one will). You'll enjoy it much more than a Fit (I don't want to read your constant complaining about their undergeared transmission needlessly sucking away precious fuel! ). Plus the Toyota has an excellent reliability track record.
RH77 (08-20-2009)
Old 08-21-2009, 12:14 AM   #4 (permalink)
RH77's Avatar
I haven't been by for a while -- there's a "Thanks" function! I couldn't help but use it
I also drive 30-35K miles a year, but generally in rentals. With a new work assignment (hopefully), I'll be commuting to 6 locations around the city, with minimal travel out of town. I've heard 200K in the past with HSD, but how common?
I'm really tempted by the Gen-III/Base. In the never-ending quest to save some cash, the Fit seems the best new car in the price-range, but may lose-out to a used Gen-II Prius. 5-door options are few. The Matrix/Vibe is OK, but I've rented it enough to know it's not my style.
I spend a lot of time at the 65-70 mph max range on the highway (the speed helps with hill climbs with about 55-60 on the load-up, slow side. But yeah, not the most efficient overall).
...So the high gearing of the Fit would definitely drive me nuts. The aero and city FE ability of a hybrid seem to be a good compromise.
Sigh. What happened to the simplicity of yesteryear? Why can't we get a Diesel Honda over here? Yeah, I know...
RH77
EF5 / 22-May-2011
_
_
Old 08-21-2009, 02:43 AM   #5 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
ive done my research in this as well
100k is when the warranty runs out
some batteries have gone 300k+
if i had the money, id get a prius
Past Present Future?
Old 08-21-2009, 10:35 PM   #6 (permalink)
Gen II Prianista
Rokeby's Avatar
RH77,
I've been driving my '08 Prius Touring for some 21 months, 30k miles. I'm
also a poster at PRIUSchat.com where I read virtually every thread on the
problems that are reported on Gen II Prii no matter their mileage...
As in any used car purchase, the watch words are "Buyer Beware," with a
few extra twists. In addition to all the typical cautions for buying a used car
-- like careful inspection for body/frame damage/repairs -- here are a few
Prius specific items:
* Inspect the actual title to ensure the car does not have a "salvage" title.
* Ask to see all the service records; 5k routine services done by dealer or
owner?
* Have a Prius tech go over the car, and get an "official" printout from the
dealer of the car's service record.
* How the car was treated for the first 100k miles will determine whether it
goes another 100k. Most folks don't know it, but it's not the High Voltage
battery that is likely to give trouble.
At ~100k miles there are a number of other things that are more likely to
cause trouble:
* the inverter cooling pump is somewhat of a weak link, and some Prius
gurus recommend replacing it and the special coolant at 100k as a
preventative measure before it leaves you stranded.
* The "transmission" fluid is due for renewal. Again the maintenence gurus
recommend that it be changed a least once, and better yet twice, before
100k miles for logevity purposes.
* The service life on the small 12v battery is ~ 4 years. Extended high or
low ambient temps lower that figure. The car cannot be started if the 12v
battery dies as it "boots" the computer that brings the big HV battery on line
for starting, etc.
* If the alignment, including the rear wheels is off, even slightly, this car
can really chew up tires -- like to the tune of only 25-30k miles a set. No
way to know what the history is here but unevenly worn tires would be a
give away.
None of the above is a reason not to be buying a used Prius. It is meant only
to help you identify a good used Prius to buy -- if you get a good
one, I'm sure you'll love it.
Lastly, even though you may only be just looking now, you should at least
go lurk on the Gen II maintenance forum at PRIUSchat.com and use the
search function to dig into the many older threads. Here's a good one to get
you started:
http://priuschat.com/forums/gen-ii-p...you-don-t.html
[EDIT: A note on PRIUSchat; it is a wholly different kind of forum than here.
There's a whole lot of ChattyCathy stuff. Don't be put off. There are also some extremely competent posters in the maintenance threads.]
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/gen-ii-prius-life-expectancy-9755.html
Posted By For Type Date
What services you need and what you don't - Page 56 - PriusChat Forums This thread Refback 07-26-2011 03:18 PM
What services you need and what you don't - Page 58 - PriusChat Forums This thread Refback 07-20-2011 10:41 PM
What services you need and what you don't - Page 51 - PriusChat Forums This thread Refback 06-19-2011 11:06 PM
What services you need and what you don't - Page 52 - PriusChat Forums This thread Refback 03-29-2011 10:27 AM
What services you need and what you don't - Page 53 - PriusChat Forums This thread Refback 03-15-2011 06:45 PM
What services you need and what you don't - Page 43 - PriusChat Forums This thread Refback 10-27-2010 04:33 AM
What services you need and what you don't - Page 50 - PriusChat Forums This thread Refback 09-28-2010 10:56 AM
What services you need and what you don't - Page 49 - PriusChat Forums This thread Refback 07-19-2010 06:48 PM
What services you need and what you don't - Page 45 - PriusChat Forums This thread Refback 06-10-2010 11:00 AM
What services you need and what you don't - Page 34 - PriusChat Forums This thread Refback 06-04-2010 02:26 AM
What services you need and what you don't - Page 48 - PriusChat Forums This thread Refback 05-30-2010 10:50 PM
What services you need and what you don't - Page 5 - PriusChat Forums This thread Refback 05-22-2010 10:01 AM
What services you need and what you don't - Page 47 - PriusChat Forums This thread Refback 04-08-2010 08:16 PM
What services you need and what you don't - Page 3 - PriusChat Forums This thread Refback 11-10-2009 04:21 PM
What services you need and what you don't - Page 44 - PriusChat Forums This thread Refback 11-02-2009 08:51 AM
What services you need and what you don't - Page 2 - PriusChat Forums This thread Refback 10-13-2009 02:47 PM
What services you need and what you don't - Page 35 - PriusChat Forums This thread Refback 10-05-2009 12:14 PM
What services you need and what you don't - Page 41 - PriusChat Forums This thread Refback 09-17-2009 01:33 PM
What services you need and what you don't - Page 4 - PriusChat Forums This thread Refback 09-15-2009 12:26 PM
What services you need and what you don't - Page 11 - PriusChat Forums This thread Refback 09-11-2009 07:51 PM
What services you need and what you don't - PriusChat Forums This thread Refback 08-31-2009 03:17 PM
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 18 08-11-2011 05:18 AM
Gen III 2010 Prius Matt Herring Hybrids 3 08-30-2010 04:04 AM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 01:35 PM
Prius III has virtually the same CdA as the Prius II Daox Hybrids 4 05-30-2009 02:48 PM
early Prius gen 1 for sale, should I? blueflame Hybrids 2 05-21-2009 09:04 PM
