Generator Propane Conversion
3 Attachment(s)
Thought I'd show my recent experince with one of these guys:
http://ecomodder.com/forum/attachmen...1&d=1505411023 Available on ebay for a whopping $25. I wasn't expecting much. Oh, I was hopeful, but still...I hate gasoline and carburetors! So for $25, I had to know. It was a direct fit for my cheap chinese generator. Swaps directly in place of the old carb, and is identical to the old carb, except for the additional propane delivery stuff and the aluminum float bowl: http://ecomodder.com/forum/attachmen...1&d=1505411040 It runs on low pressure - after some research, it turns out to be the same pressure range that BBQ regulators put out. (about half a psi) So I salvaged a regulator from a trashed BBQ: http://ecomodder.com/forum/attachmen...1&d=1505411049 https://www.youtube.com/watch?v=O2hNb6PLXOw It works! :eek: Even with a decent load on it -- not a hiccough! Not bad for $25! I'm thrilled! :D (Ok, so starting it takes some finesse, but once you work that out, it's pretty easy to do again) Disclamer: For demonstration purposes only. I am in no way suggesting anyone else does this, nor am I in any way responsible if you blow yourself up, burn down your house, or suffocate yourself. Nor do I care if your engine runs lean and burns a hole through the piston. If you chose to do this, you are responsible for your own decisions. Heck, man up and start being responsible for all your other decisions while you're at it!!!! :mad: |
I wonder if I could put that on my Honda 55 and run those little disposable propane bottles. They are only about 1/4 gallon though, and I would refill them myself. I suppose I could just put a 20# cylinder on the back rack but that's too much.
I didn't realize they have gotten that inexpensive. Thanks! |
A 1lb propane bottle holds about 10,000btu, or about as much energy as 10 ounces of gasoline.
A 20lb propane tank only holds about as much energy as 3 gallons of gasoline, but costs 3 times aa much. |
Actually I think these are dual fuel so I could have extra range as well as refill from the big tanks on my camper. |
And, yes, they're dual fuel. It can still run on gasoline. |
My small generator has a 7 gallon tank then I added another 4 gallon tank on top of it, the the big generator has a 16 gallon tank.
The big one uses 1.6 gallons per hour at half load. The 3x gasoline prices is if you use swapped out 20lb tanks. Bulk propane would be cheaper. |
On the other hand, since I don't use my power equipment much, it's nice not having to put up with gas going off and/or it wrecking the carb when I forget/can't be bothered to drain it every time between uses. I'm stoked with the idea of not having to mess around for an hour to get my power equipment started each time I go to use it. |
Why do they take an hour to start?
Someone suggested it might be the ethanol in gas these days. Then again, I let my Miata sit (sheltered, mind you) with fuel stabilizer, and it started right up. Again showing me that me and carburetors don't get along. |
