Old 06-17-2009, 11:47 PM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Geo Metro 13 inch steel wheel weight
The only reference I'd seen for the wheel weight was on teamswift:
TeamSwift • View topic - 99 metro/swift oem steel wheel weight
the older MK2/MK3 13" x 4.5" steel wheels are about 14 lbs
I weighed the tire + wheel while doing the research for Test: comparing Blackfly vs. ForkenSwift rolling resistance (Goodyear Invicta GL) ...
.... and it came out to 27 lbs with the 155/80/13 on it.
I also happened to have a loose 155/80/13 tire in the garage, which weighs 13.5 lbs. It's not the same kind as the tire on the rim though.
But assuming it's close to the same weight as the tire on the rim, that puts the steel rim weight at 13.5 lbs
Old 06-18-2009, 02:27 AM   #2 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
while reading through that test you did, I was curious about the weight of the tires
cool
Past Present Future?
Old 06-23-2009, 12:10 AM   #3 (permalink)
I'd still like to find myself a set of lightweight 13 inch rims I can stick my existing tires on - 155/80/13 - and then immediately cover up with smooth wheel covers!
But the car has an uncommon bolt pattern: 4 x 114 mm . Not too many 13 inch options out there. I can only lust after the VX rims; can't use them.
Old 06-23-2009, 09:30 AM   #4 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Try these rims:
www.diamondracingwheels.com : Mini Stock Series
$75.50 each for their 10.5 lb rims that are 13x5.5
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
Old 06-23-2009, 11:44 AM   #5 (permalink)
I should have said, "I'd still like to find myself a set of cheap lightweight 13 inch rims"
Also, the FWD style rim apparently weighs 2-3 lbs more (see note, bottom of the link you sent), which would be pretty much the same as stock.
Old 06-23-2009, 04:35 PM   #6 (permalink)
$55 each at Discount Tire.
Old 06-25-2009, 01:58 PM   #7 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Just have your rotors/drums redrilled for the common 4x100 bolt patern... It should cost less than the above mentioned wheel cost, but you'd have to have your VX wheel ready....
Old 06-25-2009, 11:40 PM   #8 (permalink)
You can do that? (Moving the studs?) That hadn't even occurred to me.
Sadly, I even used to have a set of VX rims, but sold them after I sold my 89 Accord.
Old 06-26-2009, 12:10 AM   #9 (permalink)
Wonderboy's Avatar
98 Civic - '98 Civic EX
90 day: 42.62 mpg (US)
CRXFi - '88 CRX HF / XFi
90 day: 38.84 mpg (US)
01 Insight - '01 Insight
90 day: 48.58 mpg (US)
Great information Darin, you're on a roll with awesome suzukiclone info. I really want to see a metro with VX rims on it. I hope maybe this can help one of us make it happen.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-07-2012 12:40 AM
Designing/building front wheel skirts v.1.0 (Geo Metro) MetroMPG Aerodynamics 119 12-07-2009 09:30 PM
Video: tuft testing front wheel skirts (Geo Metro) MetroMPG Aerodynamics 44 06-07-2009 01:08 PM
Geo Metro Suspension Swap (to handle extra battery weight) bennelson Off-Topic Tech 29 04-07-2009 12:00 AM
Video: tuft testing rear wheel skirts - Geo Metro MetroMPG Aerodynamics 6 07-11-2008 09:26 AM
