Old 10-18-2008, 02:59 AM   #31 (permalink)
Liqui Moly for diesels
Originally Posted by tasdrouille View Post
If the problem is just the injector nozzles you could give Liqui Moly Diesel Purge a shot. Lots of people run it straight at the fuel filter in TDIs to clean sooted injectors.
You can buy it from a TDI community trusted vendor.
Thank you...for 9 bucks I'll give it a try. Can't hurt to test it.....maybe I'll stumble onto another use! Like the time I was using Berryman B-12 Chemtool on motorbike carbs and got some on the wart I had on my finger for 30+ years. I scraped it and it was bleeding. When the B-12 hit it, I almost launched like the Space Shuttle it hurt so bad. Ha ha, wart removed forever!
Old 10-18-2008, 09:08 PM   #32 (permalink)
Kim,
Great job, hats off to you. I am wondering if you have any preliminary fuel economy data for this arrangement yet.
Jason
Old 10-19-2008, 12:49 AM   #33 (permalink)
Thanks much! But something has gone awfully wrong and one cylinder is dead. It was black smoking terribly the other day and tonight I changed a suspect injector, took it for a ride and knock knock crack crack crack....to top it off the headlight fuse blew (nothing new here, I can't find the short though) on a dark road 2 miles from home. We will see. I have a spare non running engine to rob parts from.
In 100 miles so far it used 1/8 tank of fuel down from the 3/4 mark. It also idled about 5 hours on a quart of fuel while I got the temp sensor and cooling fan circuit figuerd out. It was sucking out of a half full plastic jug so I knew how much was in there. I will also set this up so I have a calibrated gallon fuel jug hung up inside the car and see how many miles it takes to drain.
I can't wait to test it but it has to be running right first!
I flushed out the gas tank several times and hope I did not get any lingering gas in the system. I hear that it is no good for the pump. injectors, engine. Maybe I worry too much and I replaced the wrong injector...
Old 10-19-2008, 01:07 AM   #34 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
I hope it is nothing serious.
Old 10-19-2008, 01:11 AM   #35 (permalink)
...That makes 2 of us......!!!!! I'll find out in the morning.
Old 10-19-2008, 02:00 AM   #36 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
The headlight issue may be down at the fusebox where the wiring connector melts.
Old 10-19-2008, 09:35 AM   #37 (permalink)
Would this be the same inaccessable fuse box that melted the terminal to the fuel pump relay 200 miles from home? Why would the headlights go out when I was doing 50mph in a hard turn on a country road with no street lights, no gaurd rails and a 75 foot dropoff on the right? How come I'm an EcoModding "Lurker " when a more suitable description would be window peeper/trenchcoat flasher? I'm stumped.
Old 10-19-2008, 09:36 AM   #38 (permalink)
I'm not sure how similar a kubota pump is to a VW pump, but I modified my governor on my Jetta. It gave me full throttle control through the entire rpm range. There is a write up on it over at the VW GTD forums
Old 10-19-2008, 09:38 AM   #39 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Awesome.
I've seen a guy who tucked a single-cylinder Changfa diesel into a Metro. 10 romping stomping horsepower, WOOHOO! It tops out at about 50mph and has one end of the engine sticking out through a hole in the hood, but it just goes to show that 200hp isn't necessary if you're just trying to get somewhere.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 10-19-2008, 10:06 AM   #40 (permalink)
Jetta injection pump
Thanks for the info....now whose dumb idea was it to put a tractor engine in a car? I kind of knew the Kubota governor was not suited to road use. After looking at the cutaways you sent, I see that the VW pump has variable injection timing. I can't find a drawing for Kubota. But the governor/pump is part of the engine casting and there is almost no chance of replacing it with an automotive pump. Kubota timing is adjusted by shims. I don't think it has speed sensitive timing. Like Briggs&Stratton has fixed spark timing. OK for a lawnmower.....
Geo Metro Conversion - Standard to XFI SirKeats EcoModding Central 16 10-22-2010 02:44 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 02:42 AM
turbine engine for a geo metro kane66 EcoModding Central 41 10-26-2008 06:39 PM
Video: The Joys of Driving a Geo Metro in -31*C Temperatures Peakster General Efficiency Discussion 20 02-12-2008 09:10 PM
