Old 06-30-2013, 01:46 AM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.23 mpg (US)
Question about the exhaust
Was wondering during the process of burning the fuel, once the A/F mix is compressed and the piston is forced downwards, what happens to the exhaust before the piston forces it out through the exhaust valve? Does the burnt fuel stay toward the top of the cylinder or does the force of the piston going downward create a sort of vacuum which brings the burnt fuel down towards the bottom (relatively speaking) of the cylinder, or does it occupy all the space relatively evenly?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 06-30-2013, 03:25 AM   #2 (permalink)
The mixture spreads evenly, since it's the expanding/combusting air-fuel mixture that is pushing the piston down rather than the piston pulling it.
