Old 08-14-2008, 04:06 PM   #1 (permalink)
Geo Metro Fuel Filler Neck Refab
The fuel filler neck on the geo goes down the back of the fender, and is covered by a piece of plastic. Once dirt and water get up here, it's rust heaven.
My filler neck rusted 2 holes through it.
This is a Dealer only item at $366!!!!!!!! Me and the guy at the parts counter just laughed.
So on to Napa for some Fuel Filler line, and on to Home Depot for some Galvenized pipe fittings.
I needed to keep the vent, luckily, that was the only part still in good shape, so I cut about an inch below the vent, giving me room to attach a new line.
Fuel filler hose is not flexible. Radiator hose can not be used for fuel, it will eat it.
It's a little over an inch from the tire, just far enough not to rub. When I have a little more time I can make some adjustments and get it tucked in a bit farther.
Total price, about $20
Old 08-14-2008, 04:56 PM   #2 (permalink)
Had to take it out to made an adjustment to get it further away from the tire, so took a picture:
Old 08-14-2008, 08:38 PM   #3 (permalink)
Hacksaw's Avatar
GOT MPG? - '95 Metro Hatchback 3cyl/5-speed Base Model
90 day: 44.74 mpg (US)
1337MPG - '97 Metro Lsi
90 day: 36.51 mpg (US)
55HORSE - '95 Metro Hatchback
90 day: 37.79 mpg (US)
DOOPULR - '99 K1500 Suburban SLT
90 day: 9.79 mpg (US)
Scar's Tracker - '96 Tracker Base
90 day: 23.46 mpg (US)
It's all about functionality...nothing else matters.
Old 08-14-2008, 09:55 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
That saved you over $300.00 and looks like it would be very safe. Better than dripping gas all over the place!
Old 08-14-2008, 10:28 PM   #5 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Excellent work. I don't mean to be a conspiracy nut but it really is weird that there seems to be a few random "dealer only" parts that fail easily. It's almost as if they already knew ahead of time those parts would fail...
Old 08-15-2008, 12:52 AM   #6 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Safety matters too. We will see if it stays leak free.
Old 08-15-2008, 01:16 AM   #7 (permalink)
Hacksaw's Avatar
PVC version of your mod? Hmmm...
Just had a thought...would PVC be an acceptable material, or does gas effect it? It seems a better solution if it can withstand constant contact with fuel...
Hacksaw.
Old 08-15-2008, 01:59 AM   #8 (permalink)
TrikeKid's Avatar
The ClownCar - '91 Metro Base
Send a message via AIM to TrikeKid Send a message via Yahoo to TrikeKid
Hacksaw.
I know of people that have rigged fuel cells with a PVC filler. I think the ideal would be to find a buddy that can bend some exhaust tubing up for you, you could make a leak free (provided you can weld/braze well enough), stock type piece that way.
Old 08-15-2008, 02:40 AM   #9 (permalink)
Hacksaw's Avatar
True. True...
However, if I did have a buddy that bent exhaust, I'd have cat-free systems on both Metros right now...lol
Mimicking the OEM part would be ideal, but solving a problem quickly, and on the cheap, often prevails!
Old 08-15-2008, 02:48 AM   #10 (permalink)
TrikeKid's Avatar
True. True...
It probably wouldn't cost that much to bend a piece up even if it wasn't a buddy deal. Just have to make sure it's someone who knows just what the hell they're doing. My dad's truck is proof that most of the franchise shops don't. 2 bends! The kid couldn't get 2! Bends right after having it explained to him twice, and being given a drawing of just wtf he was supposed to make. Finding something with a rubber filler neck that was long enough at the junk yard might be another option.
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 10:07 PM
Need Geo Metro information.. Chris D. Off-Topic Tech 1 06-09-2008 08:34 AM
