Old 05-16-2011, 01:35 AM   #11 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Originally Posted by wyatta4 View Post
So my best bet would be some insight wheels then huh?..
What generation insight? And how much are those going to go for do you think?
First generation insight, so 2000-2007, or like was also said look at the 1985 crx si wheels, if you look at car-part.com it lets you put your zip code in and see what is close, you can have it show you images for some wheels and it will tell you how wide alot of them are, what you want is rims that came off a vehicle with 4 holes 100mm apart, tirerack.com will tell you the spacing if you put a vehicle in and look up wheels for it.
I suspect that rims are going to cost you $40-75 each, but ask at the salvage yard if they will give you a deal if you buy a whole set, first generation civic hybrid rims will also fit and are pretty smooth altho not perfect and I'm sure you will find others if you search around, but those crx si rims, honda insight are light weight and smooth.
Old 05-17-2011, 08:28 AM   #12 (permalink)
Temp - '94 Civic EX
New Found Love - '89 CRX HF
13x4-1/2 (Yuno mfr)
Carpart ^ best they had.. No si wheels.. That I know of?.. The HF tires are only bout $15 bucks a piece..
Check out my project here---> My CRX Project
I am looking for an '88 or '89 Honda CRX HF for parts (mainly interior..)
Old 05-17-2011, 09:31 AM   #13 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Your can get 155/80 Douglas tires at WallyWorld for about $22 each. Tire rack has some good 13"deals too. A set of Sumitomo HTR200 IN 175/70 is like $130 to your door.
crx
