Old 05-19-2008, 07:45 AM   #131 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
I think that console is going to be the most informative console of any automobile out there. With over 14 gauges (some repeats?), when are you going to have time to look at the road?
Seriously, awesome progress, look forward to the videos you'll post of the completed project. That is, I hope there's videos.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 05-19-2008, 11:21 AM   #132 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 metro 4 dr HB
90 day: 66.44 mpg (US)
Looking good! I'm very impressed with all the work you've put into your car. As a metro owner, I appreciate the photo autopsy you did along the way of the rusty areas. If I'm going to keep my metro on the road for years to come it's gonna need some kind of metal work. This thread will be of great help in that event.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 05-19-2008, 09:26 PM   #133 (permalink)
igo
igo's Avatar
Blue Saturn - '98 SL1 Base
90 day: 34.67 mpg (US)
Awesome work. This has gone together faster then I expected.
Old 05-20-2008, 06:25 PM   #134 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
It looks even better now
Body is installed for the last time for the most part. Have to take the drivers fender off and redrill the hood latch cable hole and run it.
Also the drivers door upper hinge and passenger lower hinge are the same so anyone looking to replace their bad upper hinges can just find opposite side lower hinges and use. That will make finding good hinges way easier.
For anyone wanting to see some pics of the old car rust here is a few shots of the floor. Large pics of it are on my site so you can see detail of how the floor on these cars typically rusts out.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 05-21-2008, 05:51 PM   #135 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Progress! Good to see some skin on it again.
I came back to this thread looking for the control arm pics (found 'em). They're going on the ForkenSwift - amazing what one winter did to them. They're swiss cheese. Structurally intact (meaning they haven't collapsed - because the main double-thickness seams are still OK), but will not survive another winter. Welding is imminent, weather permitting (car's outside, on jack stands).
Do you happen to know if I can pull the control arms off without removing the rear bracket? The front nuts will come off, but I'm afraid if I wrench hard on the bracket bolts, I'll either break them or tear them out of the floor.
I wondered if I soaked the rear bushing in lubricant if I could re&re it...
Old 05-21-2008, 07:12 PM   #136 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Neon SE
90 day: 36.28 mpg (US)
S'Crew - '02 F150 Supercrew XLT
90 day: 16.4 mpg (US)
EX - '94 Explorer
90 day: 19.58 mpg (US)
Ranger - '90 Ranger
Last 3: 28.02 mpg (US)
PB Blaster is about the best thign for rusted nuts. Squirt them a couple times a day for a few days ahead of when you do the work. I would also suggest a wire brush on any exposed threads too. Worked wonders when pulling old U bolts form the rear axle of my Ranger.
When it comes to Heroes, RENEGADES are mine!
Old 05-21-2008, 08:38 PM   #137 (permalink)
nut
Coyote X's Avatar
The rear bushing at one time probably could be removed from the control arm but I really doubt that it will be easy to get the arm out of it now on any of them that have a few miles on them
I am with Z spray something on them for a few days to get them free. I think you can get the bolts out if you spray them a few times/days ahead of when you go to take them out. If nothing else the metal is thick enough there to just drill through it all the way into the floor and stick a big bolt and washer on top and put a nut on the bottom to do away with the welded-on nut inside the body. Btw I wrote a bit more about how to repair the frames here. I added measurements from the shop manual so you can make sure they stay square.
Here are some fancy looking bumpers
Old 05-21-2008, 08:46 PM   #138 (permalink)
OK, thanks for the bushing advice. I would prefer to get them out just to make more room to grind back to clean metal, but I think I can squeak it if I leave them in while I do the repair.
Thanks for the repair link - I was looking for that at your site today.
Old 05-21-2008, 08:59 PM   #139 (permalink)
nut
Coyote X's Avatar
Another option would be take the bolts on the front bracket off and just pull the arms down out of the way so you can still get to everything.
If you have lots of time and patience you can probably use a sledgehammer and get the arms free of the rear bushing. Just make sure the car is really stable and have a backup brace in case you yank it off the jackstands. The front bushing will also be a bit of effort so just keep working at them and you will get them free.
Old 05-22-2008, 11:01 AM   #140 (permalink)
Ecomod noob
zjrog's Avatar
Neon - '03 Neon SE
EX - '94 Explorer
Ranger - '90 Ranger
I'll only add, do be careful while working and wrenching hard under the car. Over the last weekend a good friend was injured in Moab, when he crawled under someone elses vehicle to help fix a broken axle. While pulling on a part, the vehicle fell on him. 4 men and 2 women LIFTED the Isuzu Rodeo off him so he could slide out. He wad a cut on his head, but had taken a lot of weight on his abdomen. It took 45 minutes for help to arrive (Search and Rescue on ATVs and a helo). He was in bad shape with internal bleeding. He needed to be revived once during the helo flight. Emergency surgery repaired the tears in artery to his colon. He MIGHT get to go home tomorrow.
I only mention this to remind everyone to be careful. I'm a big guy, but I can't possibly bench press even a Metro. A couple extra minutes to make sure the vehicle was safe to work under would have meant a little extra time on the trail, but beers and laughter for everyone once back to the campsite. It sure could have been worse.
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 07:48 PM
Geo Metro Conversion - Standard to XFI SirKeats EcoModding Central 16 10-22-2010 02:44 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 11:07 PM
CL: Mechanics Special 94 Geo Metro Red For Sale 4 04-09-2008 02:48 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 10:54 PM
