Old 05-22-2008, 11:17 PM   #141 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Actually looks like a car now, And there are even three panels with the same body color
The list of things left is getting smaller all the time. Main things left are exhaust, cv joints, new belt and hoses, and a bit of underhood wiring. The car should run and be drivable after that. From there it is a matter of detailing it out and adding the extras to it like the full belly pan and minor stuff.
Only parts I am missing now are a drivers door window and windshield. If I can swap the windshield off my old xfi onto this one without breaking it then that saves me 300 bucks on a new windshield
My Convertible Metro XFI Plug in Hybrid Project build log
Old 05-23-2008, 12:06 AM   #142 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
The mesh in the rear bumper makes me think "Ferarri" or "Audi R8"
zjrog - that's quite the story. Glad it ended well. Point taken.
And FYI, Ivan busted the control arm bracket bolts on the ForkenSwift this afternoon. Too little patience; not enough heat and/or rust penetrator. </thread hijack>
Old 05-26-2008, 12:24 AM   #143 (permalink)
nut
Coyote X's Avatar
<script type="text/javascript" src="https://media.dreamhost.com/swfobject.js"></script>
<div id="100_0265_640x480.flv"><a onclick="pageTracker._trackPageview ('/outgoing/http_www_macromedia_com_go_getflashplayer');pageTr acker._trackPageview ('/outgoing/http_www_macromedia_com_go_getflashplayer');" href="http://www.macromedia.com/go/getflashplayer">Get the Flash Player</a> to see this player.</div>
<script type="text/javascript">
var so = new
SWFObject('https://media.dreamhost.com/mediaplayer.swf','mpl','640','480','8');
so.addParam('allowscriptaccess','always');
so.addParam('allowfullscreen','true');
so.addVariable('height','480');
so.addVariable('width','640');
so.addVariable('file','http://metroxfi.com/wp-content/uploads/2008/05/100_0265_640x480.flv');
so.write('100_0265_640x480.flv');
</script>
[flash=640,480,false,#ffffff]https://media.dreamhost.com/mediaplayer.swf[/flash]
Guess posting a video doesn't work unless it is from youtube So if you want to see the car actually start and run go here
if someone knows how to fix it to make the video show here please feel free to mess with this post.
Old 05-26-2008, 01:11 AM   #144 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
It sounds pretty good actually.
Old 05-26-2008, 01:17 AM   #145 (permalink)
TheDon's Avatar
Pepper - '87 300D
90 day: 30.42 mpg (US)
does it have a turbo or is that whine from something else?
Old 05-26-2008, 02:25 AM   #146 (permalink)
nut
Coyote X's Avatar
Most of the whine is from the amps, they don't seem to like having a battery charger hooked to the car. But I am sure some of it is alternator whine, the engine ground doesn't seem to be connected solid so I will probably add a few more ground leads in there in random places.
So tomorrow if I have time I am going to find the leak in the brake lines and bleed them again and put the radiator in it so I can drive it around and see what falls off
Probably take the rest of this week to get it all together enough to where I would be willing to take it out on the road. Still a bunch of little stuff to do before it is really done though but it is getting closer all the time. I know it won't be done by the beginning of june but depending on how much body work there is it might not be more than a week later than I planned.
Old 05-26-2008, 11:11 PM   #147 (permalink)
nut
Coyote X's Avatar
Looks much nicer with all the wires wrapped and ran carefully.
And whoever thought it was a good idea to cover the entire car in a 1/8 inch layer of bondo needs beat up I am going to have to get some 36 grit paper so I can knock it off quickly. But even with the amount I got off the trunk I can tell it is a good bit lighter so I bet there is an easy 50lbs of bondo on the car.
Old 05-30-2008, 12:04 AM   #148 (permalink)
nut
Coyote X's Avatar
Dashboard is pretty much complete now.
So now you can see the bluetooth rear view mirror, side rear view tv screens, main monitor screen, tach, and 3 gauges(egt,vacuum,oil press.), I have a few covers and trim pieces to snap on but everything on the dash works except for not having cameras hooked to the rear view screens yet.
Old 05-30-2008, 12:17 AM   #149 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Old 06-02-2008, 10:34 PM   #150 (permalink)
nut
Coyote X's Avatar
Car drives fine for a car with no brakes, 9 lug nuts total and 3 different size tires on it I drove it 3 miles back and forth in the alleys around my house, they are all dirt and I was doing 35-40 when possible to see how the suspension handled the big holes and ruts. It held up fine and is probably the most solid feeling metro around.
Now that it is basically ready to go it is time to make it look less crappy.
no more gas door
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 07:48 PM
Geo Metro Conversion - Standard to XFI SirKeats EcoModding Central 16 10-22-2010 02:44 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 11:07 PM
CL: Mechanics Special 94 Geo Metro Red For Sale 4 04-09-2008 02:48 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 10:54 PM
