Old 01-18-2008, 07:40 PM   #41 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Work sucks, I have to actually do something most of the week other than play with a car
So today I didn't have to work so I worked on the car as usual. I finished up the main structure of the frame today. I bent and fit the drivers side rail then joined the sides together so I have a nice structure to start building the rest of the car on tomorrow if the weather doesn't get super cold.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 01-18-2008, 11:44 PM   #42 (permalink)
XFi
Driving NOW
XFi's Avatar
Now - '07 Accent GS
Xspire - '97 Aspire
90 day: 47.9 mpg (US)
Wow! Now that's a project! How 'bout coming east and helping me when you are done!
XFi
Old 01-19-2008, 10:23 PM   #43 (permalink)
nut
Coyote X's Avatar
Weather was still good enough today to get some work done on the car. So I did the hardest part today, making the roll bar. I just got the main hoop done, I will do the bracing later but I figure getting that bar in and square was a good bit done today.
Old 01-20-2008, 12:02 AM   #44 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Sweet! Looks pretty good. What's the height compared to the top of the windsheild?
Old 01-20-2008, 12:13 AM   #45 (permalink)
nut
Coyote X's Avatar
It is about 2-3 inches lower than the top of the windshield. I am probably going to have to adjust it a tiny bit though. It hits a bolt on the top frame on the passenger side when opening and closing the top so something is 1/4 inch off somewhere. Other than that it works great as is. That one small pic on my last post is with the top closed and a seat put in. Here it is larger:
Old 01-21-2008, 07:01 PM   #46 (permalink)
nut
Coyote X's Avatar
It was cold today. So I didn't do much other than permanently cure the rust problems in the trunk
Old 01-26-2008, 08:37 PM   #47 (permalink)
nut
Coyote X's Avatar
One more thing done. Might get the rear suspension almost done this weekend At least I have a strong rear bumper now.
Old 01-26-2008, 10:11 PM   #48 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Looking good Coyote X. But wowsers, anyone else see those few specks of rust on her? Looking forward to seeing more.
Old 02-02-2008, 10:06 PM   #49 (permalink)
nut
Coyote X's Avatar
got a lot more of the rear cut off. The rear suspension is all mounted to the new frame except for the shock top mount. I will get that next.
The rear isn't quite as hard as it looked like it was going to be so if I am lucky it will be finished tomorrow and I can start on the front end.
Old 02-03-2008, 09:50 PM   #50 (permalink)
nut
Coyote X's Avatar
Almost have the back done. All the bracing and stuff is finished. The only thing left is to finish cutting the old unibody junk away and the back is complete.
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 07:48 PM
Geo Metro Conversion - Standard to XFI SirKeats EcoModding Central 16 10-22-2010 02:44 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 11:07 PM
CL: Mechanics Special 94 Geo Metro Red For Sale 4 04-09-2008 02:48 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 10:54 PM
