Old 09-16-2011, 12:55 PM   #1 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Grand Voyager SE
Geo Tracker help ?? Tracker owners?
Ok I want to get a geo tracker. I sat in one in the pick and pull and was AMAZING how comfortable it is compared to my Geo Metro.
I understand its essentially a suzuki sidekick like my metro is a swift??
I am look at a 4wd 4cyl AUTO (drat)
I am pretty decent at squeezing mpg's out of my cars. I can squeeze 60mpg daily out of my xfi on E10 even with the trailer attached.
I was able to ring 25.5mpg out of my pops 8cyl towncar and this included 3 trips into center city philadelphia. (or I would have gotten 26.5 27mpg i think)
My typical commute is 54miles one way few stops average max speed around 45mph (yes I drive slow to save gas) the only time I do 50mph (the PSL) is when someone is behind me and they can not pass (I don't like to be rude)
so you tracker owners. what do you estimate i might be able to wring out of this tracker at those figures? basically the plan is Metro spring and fall and winter. the Tracker when there is snow or when its JUST too hot to be without AC.
do you think I can best 30mpg? tickle 35mpg?
Next question
How difficult would a 5speed swap be? its not "too" bad in a metro. how hard in a tracker? (I have never done either)
how about a 3cyl swap? ie put a metro 3cyl engine into the tracker?
Why the auto? well around here trackers might as well be made of freaking GOLD for the going price of them.
I found one 4wd auto for $900 so it peaked my interest.
Old 09-24-2011, 04:19 AM   #2 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
the brown goat - '03 impala base model
puddle jumper - '-1807 sidekick base model
energizer bunny - '86 trooper base model
Clifford the big red dog - '84 S-10 durango
cameo mobile - '91 trooper base or S model
road master - '86 pup base model
MPG+ pup - '81 pup DLX
i have one well two, my runner was 2wd when i got it. i got one for parts that was 4wd.
ALL 4WD PARTS WHERE BOLT ON, NO WELDING AT ALL
so a 4wd can be changed to a 2wd just as easy as i went from 2wd to 4wd.
that is as long as your doner auto has the same trans and engine to keep gearing the same.
4wd springs are about 1\2" taller giving the 2wds a gvw rating of 100lbs less than the 4wd.
also there about 3,000LBs
the 1.6L 16V makes about 60hp per L of displacement quite good for its 1992.
there's a massive amount of room for improvement in the aro area in the rear of the auto. the back window gets dirty on a rock road VERY FAST.
this is somthing i have yet to even play with
gearing for them ranges from 4.30s with the 3speed auto trans common in the 2 doors.
to 5.833 gears in very rare 88\89 models
as far as my mpg it ranges from 22 when it was running on three pistons, too 33mpg going all out for mpg with E0 gas. with a few 3 to 5.5K mountain passes mixed in....
epa highway is 26 under the old rating system.
i got 24 mpg once pulling a 2,500LB U-hall trailer running it as a 4sp, when i used 5th as top gear in flat land i got 22mpg
mine has the 5sp with 5.125 gears.
Tracker and Sidekick Gear ratios
Models listed oldest to newest, per ratio.
Vitara, Grand Vitara, and XL-7 ratios will be listed elsewhere to simplify this chart
4.30X:1 Non overdrive 2 dr auto 1.6L 16v
4.625:1 2dr auto 1.6L 8v
4.88X:1 Listed elsewhere in the Vitara section
5.125:1 Most all 4dr's (Non Vitara) * Most all 5-speed Track Kick's * Most all Autos
with overdrive
5.38X:1 Early model 1.6L 8v 4dr 5-spd Track Kick's (RARE)
5.63X:1 The early 1988-1989 1.3L powered Track Kick (RARE)
skyhiranger:
I have seen several posts asking about what a certain year combo would have, so I made up this list. Hopefully, it is easy to interpret.
This list is for finding the factory axle ratio in North American (US and Canada) 89-98 Trackicks, based on year, body style, engine and tranny combo. As far as I know it is 99.99999999% accurate. There may be some oddball combos out there, and there may be variations to this list in non-North American models, but the list is correct, to the best of my knowledge, for all North American models.
89-98 Trackick gear ratios
Years....2 or 4 door...Engine type...Transmission...Axle ratio
89 2 1.3L carb. 5 speed man. 5.625
89-95 2 1.6L TBI 5 speed man. 5.125
89-95 2 1.6L TBI 3 speed auto 4.625
91 4 1.6L TBI 5 speed man. 5.375
91 4 1.6L TBI 3 speed auto 4.625
92-98 4 1.6L MPFI 5 speed man. 5.125
92-98 4 1.6L MPFI 3 speed auto 4.30
92-98 4 1.6L MPFI 4 speed auto 5.125
94-98 2 1.6L MPFI 5 speed man. 5.125
94-98 2 1.6L MPFI 3 speed auto 4.30
94-98 2 1.6L MPFI 4 speed auto 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
4.30 gears have a 10/43 tooth count
4.625 gears have an 8/37 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
I have personally verified (removed and counted) every combo on the list, except for the 89, 2 door, 1.3L, 5 speed, 5.62 combo and the 91, 4 door, 8V, auto, 8V, 4.625 ratio......but they have been verified by people who have actually removed the ratio from the listed combo.
cj:
FYI in case you come across or are looking for the following and want to confirm them
4.875 gears have a 8/39 tooth count
5.833 gears have a 6/35 tooth count (Calmini)
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
Old 09-24-2011, 11:31 AM   #3 (permalink)
looking at different autos on the road, i think the early kia suv would do much better in regards to aro, compared to the sidekick. but ive never driven one so ive not had the chance to find out the LBs of one....or what kind of mpg they get.
difference is the kia has a 2.0L engine versus the TBI 8V or EFI 16V 1.6L or in real early ones TBI 8V 1.3L in the sidekick
the kias 4wd hubs work on vac to engage, where the sidekick uses true old school auto hubs or manuals. after 15 years its easier just to change to manuals then deal with the VAC ones.
bolth use a rear drive, front engine lay out, just like a truck. makes working on it very easy. compared to front drive. granted my runner is stock with no A\C
also its not that bad to drive with the P\S belt off being a lighter auto
but man with 50psi it rides like a dang buck board. but i just live with it....
Last edited by trooper Tdiesel; 09-24-2011 at 11:33 AM.. Reason: small typing errr
Old 10-31-2011, 01:14 AM   #4 (permalink)
im guessing you did'ent get it or....?
Old 11-10-2011, 04:08 PM   #5 (permalink)
The Antichrist - '95 Discovery Plain Jane
90 day: 12.7 mpg (US)
I had a 93. 4 inch body lift and 2 inch suspension lift. 33x12.5 tires on 15x10 ford f150 rims. 5.13 gears. 5 speed. If cruising around town it's a beautiful drive. The bigger tires, if you learnto drive with make the truck more comfortable and the engine rev lower. The drivetrain is unkillable. Auto hubs are awesome despite some fans claiming they are weak, I never broke one. Mpg... Not bad for an offroad truck. Had to draft 18 wheelers on the highway, Or else it was pedal to the metal. Literarily, just to keep up with traffic. Had a snore at the top of windshield, I think it helped. Compared to my v8 TransAm at the same time mileage was good even with big tires. In three years I only busted the front axle housing once. My fault. The front was really really stuck and I applied full power.
If you want to Eco mod it slap on some tall skinny tires you'll do alright. The 33 inch mud tires i ran at 16 psi Somehing skin y you could run at higher pressure the truck would like it I once got 30 mpg out of a stock 95 16valve 5speed truck racing home from2 hours away.
Old 11-11-2011, 12:41 AM   #6 (permalink)
i think there's a lot to gane in the aro of sidekicks.
the back end is very un aro.
small narrow tires, clutch fan deletion, with the gears from a auto the 4.60 or the 4.30s
behind the 25% O\D manual trans, i think one would push near 40 mpg.
convert one to 2wd and you will shed about 150\200LBs
use the 2wd springs and lower the ride a 1\2"
