Old 02-20-2010, 10:36 PM   #1 (permalink)
Geo XFI Cam or Tranny swap.
ok so switching the transmission out of my regular 5 speed metro to an xfi tranny is possible, but is there any thing else I would have to swap in order for the car to run right? Is it possible to switch the cam to an xfi cam,without any other mods and the car run right? How do I identify an official xfi transmision at the junk yard? What will the increase in gas milage be with just a cam swap?
Old 02-21-2010, 11:40 AM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
What year is your Metro?
Old 02-21-2010, 11:52 AM   #3 (permalink)
It is a 1991
Old 02-21-2010, 01:59 PM   #4 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
The XFI had all black bumpers, but you'd have to count the turns in and out to be sure of a tranny model, AFAIK. The 8-valve had the same ratio, which may be easier to find.
Old 02-26-2010, 11:27 AM   #5 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
Base model Metros had black bumpers too. Only the LSi had the body-colored bumpers.
And the 8-valve 89-94 Swift tranny is not the same as the XFi tranny. It's a taller final drive than the XFi. 3.52 for the 8-valve Swift vs 3.79 for the XFi. Neither are easy to find, use the 3.52 if you can get it. The 1995+ Metro and Swift with the 4-cyl have the same final drive as the XFi, and those are easy to find.
Count the ring gear teeth if you want to be accurate. XFi ratio tranny will have 72 teeth. And the super-tall 3.52 Swift tranny will have 74 teeth on the ring gear. Remove the triangular metal plate to count the teeth.
Old 02-26-2010, 11:31 AM   #6 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I don't know anyone who's quantified the efficiency gain of the XFi cam - it's too hard to do in any kind of controlled fashion outside of using a dyno).
If I had to guess though, it might be worth a couple of percent improvement.
Going to the 3.52 (tallest available) final drive was worth about a 5% gain for me.
Old 11-08-2010, 06:19 PM   #7 (permalink)
Talking cheap improvements to 2000 Metro 4 cyl
So, Is it safe to say ,that driving habits have the greatest influence on making my 2000Metro lsi 4 cyl. get the best MPG ?Any recommendations about lubricants or fuel? I'm new to this game but OCD when jacked up on a new idea. Thanks in advance
Old 11-08-2010, 06:45 PM   #8 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Yes.
If you want to achieve the same with aerodynamic and other mods, you'd have to go all the way as basjoos did with his Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com
If you combine both, the results can be really stunning.
Lifetime fuel consumption :
The Following User Says Thank You to euromodder For This Useful Post:
yaamonn (11-08-2010)
Old 11-08-2010, 10:09 PM   #9 (permalink)
Driving habits are free, so they automatically return the biggest bang for your buck
They're usually where the largest initial gains come for people new to the efficiency game.
A few years back, I tried to quantify the gains from driving technique vs. mods. At the time I came up with 38% from driving, 28% from mods (the ones I had tried up to that point, anyway). 2006 retrospective (there's more where that came from) - MetroMPG.com
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Blackfly XFi? Cam swap! Update: swap completed MetroMPG EcoModding Central 19 06-04-2011 06:16 PM
91 geo Metro xfi tranny swap 4modrebate Forum News & Feedback 0 02-20-2010 12:51 AM
Metro owner mulling over swap to XFi transmission and 1-ring pistons MetroMPG EcoModding Central 10 02-04-2009 01:56 PM
Recently purchased 1994 Geo Metro XFi Z33ky Off-Topic Tech 10 11-15-2008 08:12 AM
