Old 06-17-2008, 03:47 PM   #11 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Originally Posted by ebacherville View Post
no moving parts and pretty fail safe..
Always a good thing.
ollie
Old 06-22-2008, 03:35 PM   #12 (permalink)
vtec-e's Avatar
http://www.bowmanpower.co.uk/iqs/sid...mpounding.html
quasiturbine.promci.qc.ca/QTPapiers/QTCromExhaustWP0612.doc
Have a look here. Sounds promising
ollie
Old 06-22-2008, 04:53 PM   #13 (permalink)
Pushrod - '02 Cavalier
Do you guys have any idea how weak TEG currents are? This is about as practical as replacing your car battery with a potato.
Old 06-25-2008, 05:42 AM   #14 (permalink)
vtec-e's Avatar
Have a look here:
http://radionics.rs-online.com/web/s...176+4294956707
around 650 euro for 1100 watts. How much is an alternator?
I agree the cost benefit ratio is slim but its progress. These things should get cheaper in time.
ollie
Old 06-25-2008, 06:07 AM   #15 (permalink)
JamesLaugesen's Avatar
Buell XB12X - '06 XB12X
90 day: 49.02 mpg (US)
Holden Jackaroo - '89 Jackaroo DLX
90 day: 20.12 mpg (US)
Lada Niva - '92 Niva
Originally Posted by jamesqf View Post
Or there's this: http://www.carpages.co.uk/news/tigers-22-09-05.asp which is basically a turbocharger driving a generator.
If it is basicly a turbo, then it's capturing energy from the exhaust pressure, heat is still wasted with a turbo.
Maybe still some net gain though... and I think within ecomodder scope like vtec-e says. Maybe a supercharger in reverse to drive an alternator?
Old 06-25-2008, 10:03 AM   #16 (permalink)
Tinkerer
You could do more than one of these. Turbos typically drop exhaust gases about 500 F. There is still more than enough heat left to do more work there.
Old 06-25-2008, 10:09 AM   #17 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
That totally just put the Dexter's Lab episode with potato power in my head
Old 06-26-2008, 03:38 PM   #18 (permalink)
vtec-e's Avatar
I did some more looking around on peltiers. These guys:Using a peltier to generate electricity - HomeBuiltAirplanes.com
were playing with the same idea. Turns out peltiers are around 10% efficient. Not too good then.
Now, with the turbo alternator, i think a stumbling block is in getting a generator that goes as fast as a turbo. If we gear down from turbo speeds, we are losing efficiency. I'm trying to find out more about switched reluctance motors as they seem to be whats used. Apparently they are very cheap to make. Doesn't mean they'll be cheap to buy though...
ollie
Old 03-11-2009, 06:50 PM   #19 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Here's some progress on generating power from low temperature differentials using a "reverse refrigerator" running R134a:
http://www.chenahotsprings.com/index.php?id=90
Old 03-12-2009, 06:53 PM   #20 (permalink)
Or there's this: Put A Tiger In Your Exhaust which is basically a turbocharger driving a generator.
The question, though, is why mess with band-aid solutions for the inherently inefficient IC engine. Build Stirling engines, coupled to hybrid electric drives for quick startup & acceleration.
A hybrid Stirling engine... that would be awesome.
Would still need some sort of fuel to generate the heat in order to keep a sufficient heat difference between the pistons... but i suppose diesel / lpg could be used.
