Old 03-03-2010, 01:11 AM   #41 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Delayed reply
Originally Posted by winkosmosis View Post
What do you mean? Why would the nose be pointed for the landing gear?
To make room for it, and to improve ground handling with more wheelbase.
Old 03-03-2010, 01:23 AM   #42 (permalink)
Engine Tuner
Booger - '93 Civic CX
90 day: 38.74 mpg (US)
Send a message via Skype™ to hackish
I like the OHV designs because you don't have some pesky pushrods where I'd like to see the intake and exhaust ports. I also like the 4v heads because they make a nice efficient penta-roof combustion chamber. The peak power output of an AC engine is probably more strongly related to the rod/stroke ratio they would have to use. They aren't terribly high compression for running 100RON fuel but I suspect they have a good amount of dwell since piston speeds aren't going to be an issue.
I'm not a pilot but I do spent a lot of hours in anything from a 182 up to a twin otter. The piston AC do run disgustingly rich. Can't comment on the turbines too much but I do know they sure drink the fuel!
On the diesel conversions I know the C-182 skylane conversion has an STC. If I remember correctly the TBO is about 3000h! Although they produce less power and are slightly heavier they do consume less fuel and the 230hp or so that they make surpasses even the 260hp lycoming above 6k. It's been a while since I looked at the specs but I seem to recall that they used a turbo to keep the power up. Ultimately the climb with max weight was faster than the 260hp to 10,500'. At which point we (the payload promptly open the door and jump out to lighten the aircraft so it can descend again and repeat the cycle all over :P
Old 03-03-2010, 01:34 AM   #43 (permalink)
For the Voyager flight around the world non-stop, the key was a water-cooled version of a Continental 0-200 for the main engine. It had a specific fuel consumption of .355 lbs per hp-hr. The front engine, a standard 0-240 was at least 20% thirstier. Dick Rutan was famous for adjusting the mixture to the leanest possible settings as he flew.
Old 03-03-2010, 03:20 AM   #44 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
In a fully-loaded Suburban
The answer to the question: How did the flying pigs get to the airstrip?
Video: how to Pulse & Glide in a Prius - 85 mpg! SVOboy Hybrids 47 04-09-2010 06:09 AM
Pulse and glide experiment jim-frank Success Stories 21 09-30-2009 01:02 PM
Here's what pulse 'n' glide will get you. Clev Success Stories 11 02-21-2009 05:35 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 08:26 PM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 09:06 PM
