__________________ Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it! If you have to use your brakes, you are driving too fast!
Right before i was about to leave to see the car, the guy told me he decided not to sell it..... go figure.
Ok, found a new one. This one is much nicer and is a 2nd gen! And its red!
I'm in contact with the seller now, ill keep you guys posted.
Leaving to go look at the car in about an hour. I will most likely be driving this one home today. Has a new tranny, water pump, timing belt, owner says no rust, body is straight with no dents, paint is shiney, interior is clean..... If its as described it will be a great buy.
I will definately check the things you guys have mentioned. Hes asking $995 for it, ill see if i can work something out with him.
