Old 07-26-2011, 02:32 PM   #1 (permalink)
BeatUpRanger - '95 Ranger XLT
Getting into overdrive sooner
I have a 1994 ford ranger v6 automatic. Is it possible to make adjustments that would allow the transmission to shift into overdrive sooner? I'm trying to keep it around 1500 rpms. Whenever I coast and have to start back giving it gas, it pushes over 2000 until the od kicks in.
Old 07-26-2011, 02:57 PM   #2 (permalink)
BikerModder's Avatar
I always had trouble with my '93. It was too slow at a light.
Old 07-26-2011, 11:40 PM   #3 (permalink)
Were you trying to take off quickly or what? I'm sort of getting used to driving much slower. I know making an adjustment like that will give it less torque, but at this pooint, I think it'll be okay.
Old 08-11-2011, 03:54 PM   #4 (permalink)
The Ol' Oldsmobile - '02 Alero GL2
90 day: 27.68 mpg (US)
Just go easy on the throttle. Auto trans will continue to annoy us till time ends, just get used to it.
Old 08-16-2011, 02:35 AM   #5 (permalink)
I'm here to learn!
Check and see if there is a way you can manually lock the torque converter. On my old 92 Chevy I was able to jumper two points from the ALDL connector and manually lock the converter up with a toggle switch. Something worth investigating. Your Ranger should have the A4LD transmission, if so this may be something worth looking into.
Do a search for "The Ranger Station, Installing a Torque Converter Lock-up Switch"
Might be helpfull in increased milage, and decreased transmission heat.
Old 08-16-2011, 05:14 AM   #6 (permalink)
pletby's Avatar
The Car... - '98 Contour GL
Team Ford
90 day: 30.94 mpg (US)
GS400E - '83 GS400E E
It's just as I thought! Dangit.
Best trip: 42.6mpg
Best tank: 32.39mpg
Old 08-16-2011, 09:15 AM   #7 (permalink)
ZOMGVTEK - '02 Accord
90 day: 24.4 mpg (US)
I wish I could remap my transmission's shift points... Under 'normal' acceleration it wants to rev up to 3-4K, and holds rpms before shifting. Under very high throttle or very little throttle, it works great. Also, the torque converter wont lock up until I hit 45 MPH and low engine load, whereas it could probably do it around 35 and keep the RPMs down into the high idle range.
As far as I know, theres no way to do this stuff easy. :/
Old 10-22-2011, 05:05 AM   #8 (permalink)
with lots more to do
ecomodded's Avatar
Dusty - '98 Beetle TDI
Diesel
90 day: 62.64 mpg (US)
You may be able to adjust the shift points on your Rangers Transmission.
I owned a 2005 Ranger 3L auto a couple years ago and looked into it.
It can be done thru the ecu on my truck, I remember reading that I could change it to kick in 500 rpm sooner but it may cause the tranny to have a bit of a shimmy when changing into od. My Ranger was a gas pig it was as if it was De-tuned to be as inefficient as possible.
My old 92 Cherokee with its 4L motor {5-speed} and 4" lift kit got the same mileage as the 05 3L Ranger{auto}about 20 mpg..imperial
1998 Beetle tdi
AGR motor with stock K03 turbo
5-speed with fuel pump tuning box
rims and a roof spoiler
Boost gauge
Old 11-04-2011, 11:40 PM   #9 (permalink)
Does it have a cable detent? if so you can loosen it for a little adjustment. Also if you can tie into the ecu, you can switch the OD solenoid to ground and have OD on command.
